check your lifters again
https://www.6speedonline.com/forums/...r-lifters.html
if i was inspiried after reading above thread from Divexxtreme, plus 1 for him ...i checked my lifters....especial because my lifters was made under warranty 2003 and the gt2 have had around 30000km bone stock....(the issue was a stick lifter and broken valve)
now 35000km later i checked my lifters again, because i have the old version of lifters......and found they are again out of order....now i am in a good position because i found it out before a catastrophic engine failure comes down on me out of warranty....
yes porsche made a new version...and at the end of september i hope is repaired with this new lifters
dont know exactly what you mean?
first issue under warranty ...lifter failure under warranty with stock gt2 engine...
(before i had a brand new 996tt 2002 with problems)
now lifter failure again...no problem for me after 8 years my first failure at this engine i have to pay...time to do some new mods
i discussed it those failure....this is a common problem not only on a turbo engine
no ecu failurecode, perfect idle because you use the small vario shift camshaft profile...
check your oilfilter very good ....in a later stadium you find sometimes a small nuget....it is a slow dead...
to all read this....take it easy...not everyone would have this failure...and if you have it like me,16 ours labor..1600Euro for all lifters...and it is again a new engine (except camshaft housing is gone...)
Why would you have the auxiliary chain tensioners on a motor to take it apart?
So new lifters are about 2k to replace then? Not including labor of course. And being a mechanical newbie, I would assume to replace the lifters would mean dropping the engine? That sucks since I will probably eventually have to replace them since I have a sticky lifter at cold start.
I just did the same job. Symptoms were misfires on bank 1 (primarily cylinder 3) upon acceleration. CEL flashing. Replaced all 12 intake lifters.
While the engine was out I chose to replace anything that needed updating or looked worn.
I also bought a set of coolant pipe fittings a machinist makes and got them tig-welded to the coolant block, so that I don't ever have to worry about those coolant pipes coming out from the heat cycles on the epoxy wearing. We even welded the 2 J-shaped pieces.
Also had a weird oil-pressure issue where I'd be driving smoothly and get a weird blip in the oil pressure. Wasn't the sender, was the lame rubber piping that connected to the sender. It was kinked and a twisted badly! Surely oil was coming erratically to the sending unit resulting in blips as it temporarily got around the kinks. The new part number is WAY more reinforced to prevent this from happening in the future.
update…
engine had to be divided completely
there damage to oil pumps by metal particles
found following problem my oil pump thus had some stiffness and the gears looked like something went through it some time, secondary oil-pump right side damaged, intake camshaft damaged, 1 camhousing damaged
crank, rods, piston in best conditions are the good news
so carillos will found a new home and a lot to pay..
think about to do a 3,8liter conversion, but don`t know if it is a good idea
update: engine runs again top, lifters was worn out a little and must replaced as many other parts.
reason for metal particles was a half broken timing chain...dont stress you to much with lifters...check your oilfilter and if its clean (no metal particles in it) you can be lucky
at the time i realy dont know if the noise was a def lifter ore the half broken timing chain...but i guess it was the timing chain
at least it only trust me that i had found it early enough
What's the deal with these lifters failing anyways? I've heard of the variocam lifters collapsing a bit and making noise(subsequent for replacement there anyway) but not failing completely as to cause a complete engine failure.
Have they been coming apart under load, or adding undue shock load to the timing chains causing a plate failure in the chain links?
next it only worn out on top ore have a ticking noise but not realy danger (old versions)
in my case one chain had a plate failure and the metal particles destroy many parts of my engine ..lifters was worn out on top side you can see and feel wear
only one chain on right side have a failure...left chain was okay..
jaehoppa
10-22-2015 09:17 PM
Wheel Experts
09-02-2015 09:04 AM
