Exhaust question
As far as ours we can do whatever you want... we make them per order per client...
Something to consider:
DO you mean 3" from turbo to tip? reason being is that that is a misleading statement...
A full 3' exhaust should not have any reductions including the tips.. thus if you see someone promoting a 3" exhaust make sure you look at the tips.. if they are using OEM style tips then you just reduced your exhaust to 2.1" at the end... reason being that the OEM piping is 2 and 3/8th " OD not 3"...
With that said, the smaller the diameter the quieter the exhaust... most cases I use all 3' piping then depending on the client I choose the ID of mufflers and then we make the tips which can be 2.5" or 3".
Our full 3" exhaust made 1000+ whp...
Here is proof that our X is really 3" inside...
Some details inside... ( everything is ported inside...)
fully functioning 3" dual tips
2001 996TT 3.6L and stock ECU
That's why I was asking. I do want a 3" exhaust, but also love the look of my factory split tips. I was thinking of having someone use a plasma cutter on the factory tips to open them to 3"'s if that is possible. I haven't taken them off yet to measure. I don't mind if the exhaust is loud, just no drone. Thanks for the reply.
markski
Gotcha. Thanks for the info. Yeh, I guess I really haven't heard race exhausts w/o some drone. Usually depends on the RPM's from what I have heard on my other cars with 3" exhaust systems, even ones with bafflers and straight through mufflers have some drone, but no big deal really. I'm more interested in HP gains more than anything. Thanks again!
Generally speaking a combo of 3" and 2.5" is fine...
How big is the outlet coming off the turbo? I am assuming the cats come right off the turbos.
OD is 3.25"
No, I do not think anyone does.. The turbo housing happens to be 3.25" OD.
Even OEM exhaust drops down to 2.1" at the tip
here,
look at our ski850 turbos... the OD is only 2.5" on the turbo yet we run 3" piping and this set up which makes low 700s whp ( fuel pump limitation) otherwise it will go higher...
Oct 6, 2015 03:43 PM
turbotuner20v
Sep 11, 2015 12:02 PM
