5K Hesitation funny found
Old Sep 18, 2011 | 12:11 PM
boyg's Avatar
boyg is just really niceboyg is just really niceboyg is just really niceboyg is just really niceboyg is just really nice
Unhappy 5K Hesitation funny found
Engine drop to have some vacuum and oil tube clean up, before I have plugs, coils, DVs replaced, but none of them helps.
I had test it and test it more than 20 times tonight, hesitation will NEVER happen if I floor it from dead stop, but if I floor it in rolling, whenever 1.5K, 2K or 3K rev, hesitation @ 5K would be happen.
Whats going on? I am about to mad on this for couple months.
Old Sep 18, 2011 | 12:41 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Have you tried unplugging the MAF yet?
Old Sep 18, 2011 | 02:05 PM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
subscribed
Old Sep 18, 2011 | 03:45 PM
disconnect the maf harness. its easy... if it goes away its your maf.. if not its something else..
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Sep 18, 2011 | 04:56 PM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
I had that same hesitation and took Markski's advise and did a boost leak test just to rule it out but found nothing and then swapped plugs for iridium ones and tested the output of the coils w/a multimeter and the coils checked out. My problem was solved w/new plugs.
Old Sep 18, 2011 | 06:13 PM
boyg's Avatar
Plugs were changed 3K miles before, didnt help.
MAF were tried to disconnect, car runs more worse than have it pluged.
The real funny thing is, floor it from dead stop it performs fine.
wrs
Sep 15, 2015 10:37 AM
MadWhip
Sep 13, 2015 01:27 PM
JCD911S
Sep 12, 2015 09:20 PM
