2002 Turbo Rear Tire Question
Not sure why you want to go from 30 to 35.
If you are wanting more sidewall for a softer ride, stock GT2 size tires. 235/40/18 and 315/30/18 will work on the stock 996TT wheels.
There are two things to consider.
Will it fit the wheel (and wheel well).
Is the size (Diameter or Rev/mile) within 3% of each other Front to Rear.
Someone please correct me if the 3% is wrong.
Use actual specs published by the manufacturer, not a tire "calculator".
HI,I have been running 285/35/18[25.9] rears and 235/40/18[25.4] for over 22,000 miles now without a problem,,,,as I have stated in detail in past posts and threads on this dia. topic......I was going to run 295/35/18[26.1] which will fit ... But ONLY if I could run 245/40/18[25.7] fronts...I never followed up myself to find that out with the fronts...I think going to a 295/35 rear with a 225/40[25.1] front is way out of wack??Plus the car would sit funny??.....But then again people thought that with my combo.......lol.....Good Luck....
(The non N-rated tires may have different sidewall stiffness and the effective tire diameter different enough even though the tire diameter calcuations indicate the diameters are within the acceptable range.)
Sincerely,
Macster.
2lflat4
Nov 18, 2019 05:05 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
