Track PSM effects TT vs GT-2
I am considering a GT-2 intead of a TT. My biggest concern about the TT is the PSM interfering, even when switched off, because I understand that it will reengage under certian slip and braking condtitions.
For anyone with experience, is the PSM a problem even when turned off? How much more fiun is the GT-2 at the track?
Thanks.
Thanks.
it really comes down to personal preference. For me RWD and AWD are not even comparable in terms of fun. The feeling of sliding out the rear end on a RWD car just cannot be matched.
-Steve
-Steve
Re: Switch
Originally posted by MWEELS
I wonder how hard it would be to change the drivetrain from AWD to a GT2 type setup? Has anyone done this?
MWEELS
MWEELS
The wieght of the AWD would still be there tho....
Evan
I think that the situation has to be pretty much FUBAR before PSM will reintervene. I can drift the car quite nicely with PSM off. And some professional "drifter" was able to get Chad's car sufficiently sideways to lay four nice patches of black tire marks down the road. (I suppose he could have had his PSM disconnected? Not sure....)
Dang, I was hoping for a ltittle more definative response. While at the track, does PSM interferre once it is shut off, or like Racer63 says, you have to be all bent out of shape and then you will appreciate the help?
I just ran my tt at the track with PSM off and had no intervention at all. With 600 hp and the right setting on aftermarket swaybars you can get the tail to hang out even with AWD!! Nothing quite like smoking all 4 tires either!!
during braking if necessary, to keep you from spinning. As
soon as you're off the gas, it's gone again. It's a good thing.
Joe
Donn:
I thought that once the PSM turned itself on, you would physically have to turn it off again. Am I correct? Or, does it help you and then turn itself instantly back off?
If so, way cool, I can then say oops when the light comes on instead of playing high speed lawnmower, or worse.
Tim
Tim
Donn:
Tim
Donn:
Tim
'no PSM except during braking'.
Re: Mine was
Mine was coming on all the time at the track last week. This was with PSM off obviously. I get a wierd looking hazard light.
MWEELS
MWEELS
Feelgood MD
Mar 24, 2016 09:35 AM
Mar48
Sep 13, 2015 05:30 PM
WheelB
991 Turbo Vendor Classifieds
Sep 3, 2015 10:26 AM
