996 Turbo exhaust
Old Oct 6, 2011 | 01:58 PM
MDCARR76's Avatar
MDCARR76 is infamous around these parts
996 Turbo exhaust
Thinkng about acquiring a europipe stage 2 quite. What are opinions? Thanks.
Old Oct 6, 2011 | 02:02 PM
PAULUNM's Avatar
PAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to all
IMO- best exhaust out there. I constantly have my eyes out for used ones.
Old Oct 6, 2011 | 07:10 PM
sanyata's Avatar
sanyata has much to be proud ofsanyata has much to be proud ofsanyata has much to be proud ofsanyata has much to be proud ofsanyata has much to be proud ofsanyata has much to be proud ofsanyata has much to be proud ofsanyata has much to be proud ofsanyata has much to be proud of
I recently installed an europipe stage 2 loud. The first time I started the car I was sort of keeping my fingers crossed that it wasn't going to be too loud and that I'd be regretting it. Afterward it was like, "Where's the loud?" The loud is definitely not that loud at all. I actually wish it was a bit louder and I'm not looking to wake up the neighbors or draw attention to myself. The noise doesn't fill up the cabin as much as my 993 2S did with just the motor sound pkg and modded mufflers. Go to their videos and compare the sounds between the two and you'll see there isn't much difference. Don't get me wrong, I love this exhaust and have zero drone. Just think you'll be happier with a loud if you're looking for that sweet spot sound.
Old Oct 6, 2011 | 07:38 PM
MDCARR76's Avatar
Thank u gentlemen.
Old Oct 6, 2011 | 07:39 PM
MDCARR76's Avatar
Are you happy with the hp gains?
Old Oct 6, 2011 | 07:44 PM
PAULUNM's Avatar
Unless you have big turbos (X50) then its recommended you go with a quiet.
Old Oct 6, 2011 | 07:46 PM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
I searched and considered the EP Loud also. In the end, I found that the EP was still basically the same weight as the stock exhaust. It was also considerably more expensive than other options out there. I narrowed it down to Markski's and Speedtech. Both sound incredible and are significantly less heavy than stock and the EP. In the end I chose Speedtech and I have really enjoyed it every day. Noticeable inprovement in throttle response and great sound. You can hear the turbos spool and it sings at WOT. Markski's is surely equal to the enjoyment. My only concern was that it looks so exotic, I was worried about the Smog inspection. Probably overly cautious on my part. Either way, the best two exhausts I found were those two. Heck for $400 or so more than the EP you could by both!
Old Oct 6, 2011 | 08:47 PM
sanyata's Avatar
Hmm... when I communicated with Stef of Europipe he never indicated that. Also I just spent awhile on the phone yesterday talking with a tuner who said it was a great pipe for my car which is not a X50.
Not saying you're wrong. I will pointedly ask this question of my tuner tomorrow and get back to you with what he says.
Cheers!
Old Oct 6, 2011 | 10:14 PM
Mattyrae's Avatar
Mattyrae is infamous around these parts
You need to check with Kevin at UMW, if you core change your tips it is not that much more, plus if you lose the heat shields, you get a weight savings. From the advice I have been given, it's all in the cat diameter.
Old Oct 6, 2011 | 11:35 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
HP gains appear to be over-rated by most manufacturers even with dyno runs as "proof". To get real noticible HP gains get the exhaust and a tune.
Old Oct 7, 2011 | 04:14 PM
MDCARR76's Avatar
I'm getting the europipe stage 2 quite. Installed this weekend. Thanks for all your input and opinions. Tune coming soon. Softronic? Or sport tec (I think?)
Old Oct 7, 2011 | 08:28 PM
Tpup's Avatar
Tpup is a name known to allTpup is a name known to allTpup is a name known to allTpup is a name known to allTpup is a name known to allTpup is a name known to all
I look forward to hearing your comments. I just installed mine today and I don't think the car is much louder than stock.
Old Oct 16, 2011 | 10:41 PM
MDCARR76's Avatar
To me, it's a little louder. But much better sounding than stock. Great rumble. But I've had check engine lights coming on. Is this an easy fix?
Thanks.
Old Oct 17, 2011 | 09:12 AM
ShokWaveRider's Avatar
ShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to all
I am happy with my FabSpeed Gen II with 200 Cell CATS.
Old Oct 17, 2011 | 10:23 AM
vividracing's Avatar
Thanks.
You need to do a ECU tune to remove the CEL from the highflow cats. I can help you - www.vrtuned.com
