double din bezel kit
Old Oct 12, 2011 | 12:24 PM
shredder's Avatar
shredder has a spectacular aura aboutshredder has a spectacular aura about
Question double din bezel kit
i have been looking for a radio kit. i found one on ebay for $165
http://www.ebay.com/itm/220701241299...84.m1423.l2649
is this the kit to buy and is it priced correctly?
thanks
scott
Old Oct 12, 2011 | 12:52 PM
m3ntal's Avatar
Senior Member
m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !
Yes, I just installed the same one last week.
The only gripe I have about it is that the bezel that goes around the radio with the "porsche" script doesn't have a way to securely fasten. You have to either hot glue it or build a backing plate for it. Other than that I'm happy with it and it looks factory.
While you are at it, order a upper storage bin from suncoast to replace the cassette/cd storage bin that is useless.
Old Oct 12, 2011 | 01:21 PM
shredder's Avatar
I already changed out that cd holder to a tray. I have modification plans for it that I will post when i am finished
Old Oct 12, 2011 | 03:08 PM
dailydriver's Avatar
dailydriver is infamous around these parts
I used this kit as well almost a year ago. A someone else stated, the bezel is "pressure fit" around the radio. I ended up with the thing in my back seat when accelerating hard from a stop once or twice, and given the weight of it that is DANGEROUS. I emailed the guys at Euromotorsports and they mailed me some heavy duty doublestick tape and have not had an issue since. You can get the tape at your local home improvement or autoparts store for a few bucks, or ask Euromotorsports to include it with your order (they sent mine at no charge).
Also, if you have the Bose system be sure to specify as they will modify the wiring harness for you to keep it all plug and play.
Old Oct 12, 2011 | 06:03 PM
TT996-2002's Avatar
TT996-2002 is a jewel in the roughTT996-2002 is a jewel in the roughTT996-2002 is a jewel in the roughTT996-2002 is a jewel in the rough
Me too. Same problems but other then that good to go.
+1 on the double side sticky tape
Old Oct 13, 2011 | 03:20 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
How much did Suncoast quote your for the factory double din plate?
Old Oct 13, 2011 | 08:43 AM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
Great kit, good guys to deal with, they were very helpful during my install. I share some of the same feelings re: the bezel, mine has never popped off, guess my car isn't making enough power If it does, I will use double sided tape, as Eurospeed suggested. For the money, they should just include it, not a big deal.
Old Oct 13, 2011 | 01:09 PM
I saw that the new kit includes a plastic bezel, when I bought mine it was powder coated aluminum. I imagine it is the same quality, but the lighter mass may actaully help it to stay put better...
Old Oct 13, 2011 | 01:37 PM
REVS11's Avatar
REVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond repute
Not sure anyone else had the issue that the thin cupholder "casette" above the radio has to be removed to fit this w a double din?
Old Oct 13, 2011 | 02:15 PM
m3ntal's Avatar
Senior Member
No. You need to specify if you have the cupholders or not when you purchase it.
Old Oct 13, 2011 | 04:33 PM
Slider's Avatar
I got my kit from Euromotorspeed and have never had a problem with it. Mine is the old aluminium on and it is so tight, I would need a major collision for that thing to move.
Here is a pic...
Old Sep 7, 2012 | 10:40 AM
teoulennon's Avatar
teoulennon is infamous around these parts
$165 for a dash kit is just rediculous to me..I could be wrong but I would think making a kit for a 996 would be the same as any other car.
What about these?
http://enfigcarstereo.com/shopsite_s...cENFIG_RMK_996
http://www.sonicelectronix.com/item_...c=9&zmap=26489
Sorry i cat link directly, im on the "mobile" forum.
Old Sep 7, 2012 | 11:22 AM
Slider's Avatar
Those are good, but you are missing the wiring adaptors. You could cut stuff, but it is really nice to have something that is mostly plug and play. I guess that's what the extra cash if for. There is no doubt that there is a really good mark-up there but no one else is making a full kit.
Old Sep 7, 2012 | 12:03 PM
samx's Avatar
samx is a splendid one to beholdsamx is a splendid one to beholdsamx is a splendid one to beholdsamx is a splendid one to beholdsamx is a splendid one to beholdsamx is a splendid one to beholdsamx is a splendid one to beholdsamx is a splendid one to behold
I used this to install a pioneer double din unit in my 996 recently.
http://www.crutchfield.com/p_130ADTV...ADT-VA133.html
I believe it is a portion of the install kit that is offered by euromotorsopeed sold on ebay. It doesn't come with a bezel of any kind and you need to figure out how to add a bit of rear support to get the head unit to mount securely. I added a couple of .200" thick pieces to the bottom of the new head unit, so that the new HU rests on the factory rear support.
Old Sep 7, 2012 | 12:33 PM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
Originally Posted by Slider
Here is a pic...
Slider - Did you install the booklet pouch up under your dash?
David
