HRE polished lips - can they be polished?
Old Oct 16, 2011 | 09:59 PM
muker's Avatar
muker is a jewel in the roughmuker is a jewel in the roughmuker is a jewel in the roughmuker is a jewel in the rough
I just got a set of used HREs and I am thinking of using Mothers metal polish for the lip but before I make a mistake I thought of asking. I did a small test and the polish turned black which indicates that there is no coating of any kind. Any advise welcome. Picture to follow once I detail the car!
Old Oct 16, 2011 | 10:30 PM
Hayabusa's Avatar
Hayabusa is a splendid one to beholdHayabusa is a splendid one to beholdHayabusa is a splendid one to beholdHayabusa is a splendid one to beholdHayabusa is a splendid one to beholdHayabusa is a splendid one to beholdHayabusa is a splendid one to behold
Rub away! Pics when done!
Old Oct 16, 2011 | 10:37 PM
muker's Avatar
I know it sounded obvious but better safe than sorry! Pics to follow soon.
Old Oct 17, 2011 | 01:00 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
If they are not coated, rub away. My old school Kenesis K28 were polished but not coated and I gave them the Mothers treatment once every other month. Get some detailers cotton swab sticks to get the area under the three piece bolts. It's time consuming affair the end results are rewarding.
Old Oct 17, 2011 | 09:50 AM
muker's Avatar
teaser picture
sounds good - some work ahead but look forward to the great results. This is just a teaser picture - better ones to follow
Old Oct 17, 2011 | 11:48 AM
HRE_Wheels's Avatar
HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !HRE_Wheels Is a GOD !
Nice !!!
Old Oct 17, 2011 | 12:00 PM
muker's Avatar
Thanks! This is my first set of HREs and I am simply blown away by the craftmanship! I have had other nice wheels but these look like jewels that made by hand. By the way, do you happen to know the recommended offset for 11.5 rear wheels for the 996TT. I feel the stick out a little bit but don't know if that is normal with these wheels/size or if the fit is not the exact one for my car. I already bought them so it is what it is but wondering for future purchases.
Old Oct 17, 2011 | 12:30 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Get some metal polish, an electric drill and a mop head and get to work
I've got a set of speedlines that I'm messing with at the minute trying to find a nice finish for them
Old Oct 17, 2011 | 12:31 PM
ant_8u's Avatar
Do you know what offsets you have at the minute?
I've got 11s on the rear with an ET25 and that's probably as far as you'd want to go
Old Oct 17, 2011 | 12:34 PM
hasauto's Avatar
hasauto is infamous around these parts
seems like same issue I am having with my HREs. I raised the car .5inch, rolled the fender and put more camber!!
Old Oct 17, 2011 | 12:41 PM
muker's Avatar
I need to double check the offset but I think I read ET40 and they are 11.5 rears. Call me dumb but I have never been able to do the math on offsets despite having read the clear diagram at tirerack....
I read on amazon that the Mothers Billet polish is good so will order that one. By the way, I have a griots 3' polisher so I am hoping that will work better than the drill and mop head
Old Oct 17, 2011 | 12:47 PM
muker's Avatar
offset calculation
my rudimentary math says that your wheels are 254mm minus 25mm of offset = 229mm.
Mine would be 267mm minus 40mm of offset = 227mm (or about 2mm more flushed than yours).
Please correct me if this is wrong!
Old Oct 17, 2011 | 12:52 PM
ant_8u's Avatar
Try again
http://www.1010tires.com/wheeloffsetcalculator.asp
Old Oct 17, 2011 | 02:59 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
Look at the stamped serial #...
R8H18P39xxxx 39 is the offset in this case (for my front wheels).
Old Oct 17, 2011 | 06:35 PM
muker's Avatar
Do you know what is the offset for your rear wheels?
I saw the numbers stamped inside so figured that the last two were the offset. Just curious to see what other 996TT are running for the rears. Note mine are 11.5 for the rear. Thanks
