rear tires inner treads gone..
I had another post regarding rear tires needed for my 996tt... what is needed to prevent the inner tires from getting so worn out? I have seen rear adjustable control arms.. and rear adjustable toe links.... are both needed or can I get buy with just the adjustable control arms? I want to get the proper suspension pieces so I get the alignment done correctly... going thru rear tires in 4000 miles is not cheap thank you
you should be able to lower your car just fine with coilovers...
yes, if you want to go SUPERLOW, you will have issues, but with just coilovers you should be fine. You need to get an alignment that does not have as much camber. Check out the euro gt2 settings.
He can lower his car using just the other stock suspension components with a few caveats.
- Don’t expect GT-2 ride height. As you lower the car negative camber and toe in increase. Camber adjustment move inversely with toe in. Less negative camber gets you more toe in and visa versa.
- Stick with factory width wheel and tire widths. Wider wheel and tires (315x25x19r) only exacerbate the problem.
The right inner rear does wear faster due to the torque bais and lack of LSD.
thanks guys, it seems like there are many different answers... my car is already lowered on PSS9 .. dont know anything about sway bar drop links... only issue I am having is the inner edge of my tires go real quick, and yes the passenger side is worse then the drivers side... thank you all for your replies
The rear camber can be adjusted on the concentric bolts for the control arms. They are normally very difficult to turn as they almost never get turned from new, It is possible to reduce neg cam from factory to just under 1deg . This will make a huge difference with tyre ware.The only down side to that is a very small amount of traction loss on fast bends. But unless your track orientated you wont notice too much. What you will notice is the car will in fact have a little bit more straight line traction especially doing hard 1st gear drag style starts.
For the first time last spring I noticed the same wear. As opposed to putting Michelians on (due to high price) I bought Hankooks - I'm thinking I notice a bit of difference during my daily driving but since I do not aggressively drive or track I think they ok. I will now look for the wear to appear again since I did not change or adjust anything (car is totally stock). I was told all of the settings (camber et al) were such that the car was designed to be tracked or driven harder than I do. If I have to do Hankooks every 4,000 miles I think I'll be ok with that rather than mess around the settings. Besides I do not know of a respected porsche tuner or indie shop near me.
A
A
So have you attempted to dial out some neg camber, I have PSS10's and will be running 1Deg neg cam on the rears for exactly the reason you have. ie tyre ware on the inner edges.
Wait. Why the right one?
Minimal TOE is much more important than camber when it comes to inner tire wear. I run -2.1 rear camber (with -2.0 front) along with 1/32" rear toe per side (1/16" total) and my rears wear very even across. When I ran factory spec toe with even less camber my inners wore pretty quickly. The sure sign that you have too much rear toe is the inner 1" of the tire wearing fast. With too much camber the tire will still wear uneven to a certain degree but over a much wider portion of the tire tread.
a few years ago, I recall a shop telling me that the car should be aligned with a near empty fuel tank.. as per porsche... has anyone else heard this? is this correct?
