Exhaust - Nuts Totally Corroded!
Old Jan 15, 2012 | 09:24 AM
  #106
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Originally Posted by jpflip
OUCH!!!!!! I feel your pain I am so sorry for you. You've worked so hard....
Old Jan 15, 2012 | 09:29 AM
  #107
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
**** me Ant, how do you manage to bring some humour when its so bad. Your better than me I can tell you, my toys would have been well and truly thrown out of the pram
Whats the next move......engine out I would suspect. After all your hard work, what a fooking ****....really sorry to hear this matey.
Old Jan 15, 2012 | 09:41 AM
  #108
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
I forget if you are putting in studs or bolts. But in the one hole you should put in a stud. Most importantly when you tap this hole get a slightly smaller tap that is used for an interference fit or a slightly larger stud and use a thread locker or sealant. You'll be fine.
Old Jan 15, 2012 | 11:47 AM
  #109
ant_8u's Avatar
Thanks Nick, as ever I think you're right
I don't think it's all that bad now I've had time to assess the situation
My plan is to tap the hole and put a bolt in it
I'll then grind the head off and just drill it again
Once I've ground the head off the bolt I'm basically be back to where I was to begin with - No great shakes
What I can't decide is this:
I have some spare (longer) stainless bolts
I can't make my mind up whether to use one of these as the 'plug' or whether to get a length of aluminium and use that after threading it
What do you think?
Any difference between using stainless steel or aluminium here?
I've spoken with my father too
He used to work as an engineer for Rolls Royce many moons ago
He told me things like this would happen from time to time
Apparently they would simply inspect the item to check if it's performance or properties had been compromised
As long the item would still perform correctly, it would be fixed rather than replaced/scrapped, and used as was
So, I'm thinking I'll be alright with plugging and sealing it
Old Jan 15, 2012 | 11:50 AM
  #110
ant_8u's Avatar
Here's a picture to highlight what I've drilled
Doesn't look serious at all
Just plug it and start again
Old Jan 15, 2012 | 12:07 PM
  #111
nick49's Avatar
I'd use aluminum as it will have close to the same expansion rate as the head and also be easier to drill through. You will first have to thread the hole and most likely thread an aluminum rod to fill the hole, use a thread lock or it may leak under pressure. Did you just go too deep and punch into the jacket?
The only problem with plugging the hole and redrilling and rethreading is that you will most likely remove most of the plug leaving small fragments with little integrety causing more issues. This is unless your plug is only say 1/4" or less in length and fits only into the very bottom of the hole. In this instance you would want a tapered plug with pipe thread that will wedge in and not fall into the jacket. This plug would have to smaller in diameter than the original bolt hole to work properly.
I'd just leave it as is, thread it for a stud with an interference fit. Easy and effective There may be other options. It's easier seeing the problem in the flesh to find a viable solution. GL, let us know how you address the issue.
Old Jan 15, 2012 | 12:31 PM
  #112
ant_8u's Avatar
Thanks, I was thinking the same about using aluminium
I got a cobalt drill bit today - It was the first time I've used one of them
It drilled through the stud without much of a problem, and once it got into the aluminium head itself !!BANG!! It went through it instantly
I can't believe how vicious these cobalt bits are
....thread it for a stud with an interference fit. Easy and effective....
That was my first thought, but since the manifold is held to the turbo with studs you can only remove the manifold (if I ever needed to in the future) by moving it down and sideways - Something I couldn't do with a stud in the head
It looks like it needs to be a bold in there
Can you tell me a bit more about what you meant about possibly having problems with putting a 'plug' in it?
From what I can make I think the total thickness of the casting is around 40mm
Of this, 30mm needs to be threaded for the bolt, and the remaining 10mm needs plugging up
Old Jan 15, 2012 | 03:03 PM
  #113
ant_8u's Avatar
The hole I've drilled is 5.5mm
I can buy aluminium rod is either 8mm or 10mm diameters
The cylinder head should have a M8 thread for the fixing bolt
What size bar should I plug the head with?
Old Jan 15, 2012 | 03:38 PM
  #114
nick49's Avatar
First off you need to plug the hole so it won't leak any coolant under pressure and hold for the rest of the life of the motor. I think it would be difficult to do just with a threaded aluminum made stud. You need something like a 1/16 NPT plug that you can tighten into the bottom of the hole that will seal by using a wedge effect on the threads. This will require tapping a 1/16 NPT tapered hole. Problem is the tap is too short and too fat to fit inside the threaded 8 mm hole. You will have to research this and if you think it will work, you will have to modify the tap to fit by grinding down the largest part of the OD while allowing it to still cut thread as needed. You'll also have to braze an extension for the drive. If unfamiliar with using NPT plugs, they are tapered and you will have to determine how to match the depth of hole threads with where you want the plug to tighten. I think it will work just fine, I do this stuff all the time. Here's a link to the plug dims:
http://www.alphathreadgage.com/refsheets/REFnptpipe.htm
Old Jan 15, 2012 | 05:10 PM
  #115
ant_8u's Avatar
Hadn't seen those tapered threads before
My thinking is that the hole is too deep to use this method - I might be completely wrong though as I'm only just starting to find out about them
My initial idea was to use the aluminium bar with a thread sealer on it
I think as long as it had a thread sealer in place I'd be ok??
If that isn't a option would something like the picture below work?
It's an NPT Allen head plug
Could I fit this to the bottom of the hole (with a sealer) and then carry on as before?
Not sure if I can use a plug like this, or if they're meant to remain surface mounted
I know they're used for blocking oil ways and water ways on engine blocks
Old Jan 15, 2012 | 05:49 PM
  #116
nick49's Avatar
That's exactly what I was talking about. You'll need the smallest one commonly available, 1/16 NPT, steel, aluminum or brass, doesn't matter. Follow my directions in a previous post.
Old Jan 16, 2012 | 08:44 AM
  #117
ant_8u's Avatar
Thanks Nick
I've checked the catalogue at my local fasteners place
They only have standard metric thread sizings
Is it a difference in threads which causes them to seal?
I've attached the catalogue below
They're called 'grub screws' and are located at the bottom of page 101
(page 11 out of 20)
http://www.fixings-directcentral.co.uk/Section%207.pdf
Are they any use, or no good to me?
Old Jan 16, 2012 | 09:10 AM
  #118
ant_8u's Avatar
Whenever I do any plumbing jobs I tend to use Laco Slic-Tite Paste
Do you think this'd be good to use here too?
http://www.jbind.com/products/produc...aspx?SKU=42019
Old Jan 16, 2012 | 09:49 AM
  #119
nick49's Avatar
OK, you don't want a grub screw. They are for securing a pulley on a shaft, a fastener of sorts. We don't want a fastener, we want a plug, to plug a hole. The only thing that will do is a 1/16 NPT with an allen (internal hex) head. NPT stands for National Pipe Thread. In a 1/16 size it has 27 TPI, Threads Per Inch. The 1/16" size is actually about .31" OD for a length of 1/16" pipe. Pipe sizes are measured by it ID, Tube sizes by OD. You can google 1/16 NPT, add tap and plug to learn more.
Again, as you learn more, reread my previous posts about modding the taps. They will make sense.
Old Jan 16, 2012 | 09:57 AM
  #120
ant_8u's Avatar
Thanks again Nick
I can't begin to tell you and everyone else that's helped so far how useful you've all been
I think I'd have admitted defeat if It weren't for everybody replying to my stupid questions
I'll keep reading and learning, and will refer back to your posts for pointers
I'm sure with more reading it'll begin to make sense
Again, thank you for all your help so far Nick
