Looking for a higher RPM gauge for a 996tt
Old May 4, 2005 | 09:17 PM
cjv's Avatar
cjv
Moderator
Does anyone have a source for someone who can make a higher reading rpm gauge for a 996tt? I would like to use the same stock set up (location, face size).
Old May 4, 2005 | 09:32 PM
JarodL's Avatar
JarodL is a glorious beacon of lightJarodL is a glorious beacon of lightJarodL is a glorious beacon of lightJarodL is a glorious beacon of lightJarodL is a glorious beacon of lightJarodL is a glorious beacon of light
Re: Looking for a higher RPM gauge for a 996tt
How many RPMs does it need to go to
Old May 4, 2005 | 09:44 PM
red944's Avatar
red944 has a reputation beyond reputered944 has a reputation beyond reputered944 has a reputation beyond reputered944 has a reputation beyond reputered944 has a reputation beyond reputered944 has a reputation beyond reputered944 has a reputation beyond reputered944 has a reputation beyond reputered944 has a reputation beyond reputered944 has a reputation beyond reputered944 has a reputation beyond repute
My guess would be at least 10K
Old May 4, 2005 | 09:55 PM
Zippy's Avatar
What's your view on Autometer? I have an pillar mounted boost gauge of thiers in my suburban which seems to work well. I'm not sure if they do what you need.
Mike
Old May 4, 2005 | 10:32 PM
Hamann7's Avatar
Porsche Fiend
Hamann7 is infamous around these partsHamann7 is infamous around these parts
How about a GT3 or Carrera GT gauge?
Old May 4, 2005 | 11:16 PM
red944's Avatar
I dont know how well a CGT one will work considering its for a V-10.
Old May 4, 2005 | 11:40 PM
cig1's Avatar
Wannabe
cig1 is infamous around these parts
Tachometer
Old May 4, 2005 | 11:48 PM
ZAMIRZ's Avatar
ZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud of
I don't see how the number of cylinders makes any difference in the tachometer readout. I would guess all that needs to be done is some adaptation of the C-GT sending unit to make it work properly.
Anyway, Chad, North Hollywood Speedometer does a lot of work on the older 911 gauges and I highly recommend them as a starting point at the very least.
NORTH HOLLYWOOD SPEEDOMETER & CLOCK COMPANY
6111 LANKERSHIM BOULEVARD, NORTH HOLLYWOOD, CA 91606
Phone: (818) 761-5136
Old May 4, 2005 | 11:51 PM
red944's Avatar
Im just going by the last time I installed a tach (autometer) one wire read how many times a second the spark plug was energized so you had to make sure the tach was set for the right number of cylinders. Factory ones might just get input from the ecu. I am no expert.
Old May 5, 2005 | 05:20 AM
dbelleperc's Avatar
I soon will be a supporting member
dbelleperc is infamous around these parts
Second North Hollywood.
Old May 5, 2005 | 07:31 AM
cjv's Avatar
cjv
Moderator
Re: Re: Looking for a higher RPM gauge for a 996tt
We would like it to read 10K. We currently have a SPA digital mounted on the column wihich works abeit a bit small. The OEM one in the cluster needs to be changed, modified or ? as it will constantly be pegged.
Paintballzen
Oct 10, 2020 12:22 PM
Feelgood MD
Mar 24, 2016 09:35 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
Turkish
Sep 4, 2015 07:12 PM
AuZZie
Sep 2, 2015 04:26 PM
