Race Gas
Old 10-19-2003, 08:37 AM
cjv's Avatar
cjv
cjv is offline
Moderator
Once, I attained 500 rwhp I switched from Mobil 0-40 to Swepco 15-40. Swepco is 100% synthetic and the 15-40 is better for a racing output motor. Now, I would not use this oil in areas experiencing temperatures below 33 degrees F.
Old 10-19-2003, 02:04 PM
Chris Y.'s Avatar
Chris Y. is on a distinguished road
cjv...
Could you enlighten me why the change to 15w-40? I always thought for warmer climates such as So. Cal, we didn't need such a thin oil like 0w-40. I've also thought about using a little thicker oil such as 15w-40.
I heard it's because of the variable valve system in our cars (variocam, i think) that requires such a thin oil weight. True???
Old 10-21-2003, 06:50 PM
cjv's Avatar
cjv
cjv is offline
Moderator
Chris,
0-40 is not the best oil for a highly modified motor. By the same token highly modified motors are usually not run in freezing areas. The Porsche is designed to run in all conditions therefore
0-40 oil.
Old 10-22-2003, 03:06 AM
Chris Y.'s Avatar
Thanks cjv...
Based on your experiences, have you found 15w-40 to work best for you? My car doesn't see any temperatures below 60F...would the change to 15w-40 be a good idea?
Thanks in advance!
Old 10-22-2003, 10:06 AM
Ron @ PESTuning's Avatar
Ron @ PESTuning is on a distinguished road
Originally posted by KPV
I was thinking it may be a good opportunity to gas up with some 100 octane at the Tail of the Dragon meet in North Carolina. Does anyone know if there is a station in Asheville, NC that has 100 octane? They simply don't sell the stuff in NJ.
Ken,
In NJ you can purchase 100+ octane at a few stations they are few and far between though. One place is located IIRC on either RT4 or 46 in Fort Lee. There is also a location in Raritan, which took me close to 1 hour to find as it is a small station. When all else fails you can usually pick some up at the closest race track.
Old 10-22-2003, 10:58 AM
Parker's Avatar
Parker is on a distinguished road
Have any of you tried mixing with Toluene? pretty clean as far as i've read and been told.
http://www.vtr.org/maintain/gasoline-octane.html
I haven't tried it yet.
Old 10-22-2003, 11:01 AM
Parker's Avatar
here's another link worth reading...
Rocket Fuel ~ Octane Boosting
04-28-2022 12:38 AM
BlackMarketRacing
12-08-2015 01:49 PM
The Oss
08-24-2015 08:19 PM
Quick Reply: Race Gas
