alpha 28's vs alpha 30's
Old Dec 6, 2011 | 12:33 AM
ek9max's Avatar
ek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud of
Pros and cons?
It's a summer daily driver and do the occasional highway pull. Will never be tracked....
Old Dec 6, 2011 | 06:43 AM
TiALSport's Avatar
TiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond repute
tip or manual?
Old Dec 6, 2011 | 07:04 AM
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Originally Posted by TiALSport
tip or manual?
manual
Old Dec 6, 2011 | 09:51 AM
ek9max's Avatar
6 speed.
How much spool am I really loosing? How much up top will I be gaining?
Will the alpha 30's spool like my k16's?
Also. I'm planning on keeping with pump gas. No meth. Just bigger injectors and a tune.
Old Dec 6, 2011 | 09:54 AM
suscribed
Will Alpha 3076's spool like 24/18's?
Old Dec 6, 2011 | 10:37 AM
johnspeed's Avatar
HI,Sounds like the A28s would be better for the way you plan on driving,since it sounds like you are going fron K16's...IMO....Good Luck
Old Dec 6, 2011 | 10:42 AM
MBailey's Avatar
For DD duty I would recommend the A28s. Similar response threshold as K-16s. Still have good pull up top (vastly superior to K-16s). You will be amazed coming from K16s...
Old Dec 6, 2011 | 11:37 AM
ek9max's Avatar
Right now I have intake/exhaust/1.0 bar tune.
Would my car with a28's/tune/injectors/clutch/intercoolers blow the doors off my current setup?
Old Dec 6, 2011 | 11:44 AM
MBailey's Avatar
Yes, by about 100-125 whp!
Old Dec 6, 2011 | 01:00 PM
TiALSport's Avatar
Yep A28's are for you, unless you plan to get crazy down the line and don't want to buy turbos twice
Old Dec 6, 2011 | 01:56 PM
sounds like A28s would be a better option for you.
#TeamAIM
Old Dec 6, 2011 | 01:58 PM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
Pros and cons?
I considered 28's but went with the 30's so I wouldn't want more later and do it all over again, I added the inlet pipes and have 50/50 meth, 5 bar and 72# inj and love it, I track mine quite often so I added boost controller - the car is an absolute blast on the track. I kind of wish I went with 76's now???
Old Dec 6, 2011 | 02:14 PM
johnspeed's Avatar
Originally Posted by PAULIEWALNUTS
suscribed
Hey, Good question.....How about the 3071's??....
Old Dec 6, 2011 | 03:31 PM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
tip or manual?
why would this matter?
Old Dec 6, 2011 | 03:39 PM
ek9max's Avatar
How much more power would the alpha30's be? same mods...
