A30/76
Old Dec 15, 2011 | 11:04 AM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
A30/76
Hello,
i would like to know if someone is running A30/76 on stock maf?
Old Dec 15, 2011 | 11:14 AM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
I am. I was worried about blowing mafs but EPL assured me it would be fine and Tony was right. Runs great! I had the Proto intake (Ford MAF) and hated the way it drove.
Old Dec 15, 2011 | 11:27 AM
what boost are you running?is it on stockfuel pump?if you dont mind.Thanks
Old Dec 15, 2011 | 11:43 AM
I run those on stock MAF. MAF blew after about 2 months on them. MAF was stock - never replaced in 10 years so it was most likely time for it to go. Car runs very smooth.
A3076 Billet
Markski 900hp fuel system
EPL Tune with 72# Injectors on stock FPR
1.5bar on 93 and Meth
#TeamAIM
Old Dec 15, 2011 | 11:51 AM
dgreen78's Avatar
1.7 pump/meth. I do have head studs and rods.
Dual in-tank pump setup like Evoms.
Old Dec 15, 2011 | 02:05 PM
ttboost's Avatar
Stock MAF is best for driveablity, and not sure you give up too much at a certain level. Blow through MAF MIGHT be better for higher HP levels, but driveability can't be matched by a stock MAF...
Old Dec 15, 2011 | 05:31 PM
Its all about the install and leak free set up... it does act up if you have huge after market throttle bodies or dvs on Y pipe... get some oscillation at idle because it disturbs air flow to the maf... but done right you at least can tune for it because you are within maf range... otherwise it's all an arrow in the air... but you already know that lol
here I did Arron's car and had no issues first time with idle and drivability...
Yet I know of 2 A3076s( both on 6speed running OEM maf) and from 2 different tuners and they both are having issues...
In my opinion it takes a lot in either case to get it right...
markski
http://youtu.be/mvpiS-DD3OY
http://youtu.be/j7-Ol0jaUMM
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 15, 2011 | 06:38 PM
MBailey's Avatar
Hitachi MAF never blows and drives like stock, imo
Old Dec 15, 2011 | 08:28 PM
John@SpeedTech's Avatar
When utilizing the OEM MAF and intake platform with upgraded turbos (which I prefer after having owned both a blow-thru Ford MAF kit and back to OEM), it's best to upgrade the intake plenum and piping to allow more air flow to the turbos.
We produce a great kit for this application (pictured below), which we highly recommend for anyone upgrading turbos, while running an OEM style MAF.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Dec 15, 2011 | 09:07 PM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
Mark, that silver car looks familiar for some reason.
My blow through does drive just like stock.
Old Dec 16, 2011 | 06:31 AM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
its not the car its the driver
Old Dec 16, 2011 | 09:20 AM
Does someone tried to use a 500 ohm resistor on the maf signal wire ?
Old Dec 16, 2011 | 12:45 PM
have you asked Switzer what he suggest since your using his kit?
Old May 6, 2012 | 09:25 AM
worth it to upgrade turbos from A28s to A30/76 sure with bigger Y pipe ,fender intake and meth injection?the car already has monster ic big injectors etc.. ,,and thinking to run race pipes ,NO EXHAUST.
Old May 6, 2012 | 10:28 AM
unvmy996's Avatar
this has been beaten to death several times, contact your tuner .
