What can I expect from CM stage 3 and a dual mass FW
Old Dec 19, 2011 | 08:12 AM
powderjay's Avatar
powderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to beholdpowderjay is a splendid one to behold
Time to fish or cut bait. Need to have the clutch done this off season. Have the clutch, now I need the flywheel. After reading countless threads still a little confused. I'm leaning towards the dm flywheel as I enjoy my clutch feel now. Will pedal feel the same with this set up?? or will there be a drastic change? Trying to get this right the first time. TIA. Matt
Old Dec 19, 2011 | 08:43 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
I like my dual mass, with the CM setup (now). I have the stage "4" and it really sucked . . .till I did the GT2 slave conversion. I would do both at the same time.
oh.. and while you have it out do your inlet pipes as well!
Old Dec 19, 2011 | 08:52 AM
I have the CM stage 3 and OEM dual mass flywheel and its not bad. it takes a while fo that clutch to break in. it doent chatter 80% of the time, but you have to be quick about getting off the clutch pedal...
#TeamAIM
Old Dec 19, 2011 | 08:54 AM
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
Same as above, with the gt2 slave delete the car is a pleasure to drive
Old Dec 19, 2011 | 09:00 AM
johnspeed's Avatar
You can first remove the booster spring from the clutch pedal and see how that feels....It just made a bit of a difference to get a little more feel and more livable......
Old Dec 20, 2011 | 12:13 PM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
What are you referring to about doing the inlet pipes while the clutch is out? I'm upgrading to a CM 4 and LWF after the holidays. Thanks
Old Dec 20, 2011 | 12:46 PM
XLR82XS's Avatar
Turbo intake plumbing from compressor housing to MAF.
Old Dec 20, 2011 | 01:04 PM
uschoice's Avatar
Is this something that can only be done while the tranny is out? My '05 has 20k miles, so is the inlet plumbing in need of a replacement? Thanks.
Old Dec 20, 2011 | 01:14 PM
tvurt's Avatar
The turbo inlet pipes are a nice upgrade, and easier to do with the tranny out. The factory ones do not need replaced unless they are leaking.
Markski, evom, speedtech, USP all make some nice ones.
Tom
Old Dec 20, 2011 | 07:11 PM
roseylv's Avatar
roseylv is a name known to allroseylv is a name known to allroseylv is a name known to allroseylv is a name known to allroseylv is a name known to allroseylv is a name known to all
Do you know for certain the flywheel is need of replacing? I'm in the same boat although I have just started to do some clutch research. I'm hoping my FW is still in good shape. I may convince myself to go big while everything is out. Do inlet piping and also injectors. Let us know what route you go.
Old Dec 20, 2011 | 07:57 PM
johnspeed's Avatar
Hi,Most likely if you didnt abuse your car and replace the clutch before it starts to slip ,the flywheel should be find...Also if you put injectors in you will need a new tune and if your car is stock,I dont know if their is a tune for that???.....
Old Dec 21, 2011 | 02:46 PM
John@SpeedTech's Avatar
IMO, when doing a new clutch you should replace the flywheel, unless it's real new. If you don't, there is a good chance after spending money on all the other parts and labor, your engagement may not be "like new" i.e. a bit of chatter, due to a new disk and older flywheel. It's a risk that I personally do not take, as I have seen it happen before...you are best to go with all new parts, for an all new clutch system. Then it's perfect when you drive away and everyone is happy.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Dec 21, 2011 | 03:03 PM
powderjay's Avatar
That was my thought. Only want to do this 1 time. Thanks for the input guys.
Old Dec 21, 2011 | 03:53 PM
Thales's Avatar
Thales has a spectacular aura aboutThales has a spectacular aura about
I'm having a EVOMS Stage 1 clutch and GT2 Master/Slave put in my 996TT as we speak. The technician will be able to visually see if the flywheel needs replacing, correct? I've never personally seen a damaged flywheel, but it was my understanding that a good tech will be able to tell while the trans is out. My car has 22k mi and I was only able to get it to slip in 4th gear under full boost. I have no reason to think it was abused previously..
Old Dec 21, 2011 | 04:04 PM
SaMaS's Avatar
SaMaS is just really niceSaMaS is just really niceSaMaS is just really niceSaMaS is just really niceSaMaS is just really nice
experienced tech should be able to tell you if your old flywheel is good
