Happy 2012 guys!! Anyone know how to undo this pipe?
Old Jan 2, 2012 | 05:55 PM
pwdrhound's Avatar
Originally Posted by Yazz911TT
Thanks Todd! TurboTodd.....are u Protomotive Todd?? So pinching the two parts together releases it?? Is that right? And by the looks of it they are both 19mm?? I only have one 19mm wrench I'll go borrow one. So I get 2 19mm wrenches, squeeze them together, then unscrew the connection??
Yes, exactly. You need 2 19mm wrenches to the best of my recollection..
Old Jan 2, 2012 | 11:29 PM
Yazz911TT's Avatar
Yazz911TT is infamous around these parts
thanks Todd!! maybe 2 stubby 19mm wrenches will wrk better! Any chance you have the part number for this hose??
Thanks for the part number PWDRHOUND!!
Old Jan 2, 2012 | 11:34 PM
pwdrhound's Avatar
no problem....
Old Jan 6, 2012 | 05:51 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Yazz
Where did you get your GT2 clutch stuff from?
Did you get the pieces together yourself, or did you buy the kit?
I'm thinking I should do mine pretty soon
Old Jan 8, 2012 | 05:43 AM
Yazz911TT's Avatar
Originally Posted by ant_8u
Yazz
Yea I followed Scott's thread about the GT2 Mod DIY. I literally copy and pasted part numbers and ordered them up. You dont really need to extend the pipe, only if you are **** enuf to want to seat it in its exact stock position. The Power Steering pump bit is the most annoying part, change your Aux/serpentine belt while your at it. Its a very messy job, on this part. The rest is easy.
On a separate note.........I GOT THE POWER STEERING RETURN PIPE OFF!! WOOHOOO and I got the end bit that was stuck in the tank out as well!!! THE SEAL IS FINE!!! NEW PIPE TO BE PICKED UP ON TUESDAY!!
Old Jan 8, 2012 | 07:35 AM
ant_8u's Avatar
Yeahhhhh Buddy!!!!!!!!!
Good going
Old Jan 8, 2012 | 07:40 AM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
Congratulations, nothing like the satisfaction of doing it yourself
Old Jan 11, 2012 | 11:36 AM
Yazz911TT's Avatar
Guys I received my new pipe today but the red clip seal thingy didnt come with it!! I need a new one....any1 know a part number or what its called so i can get some of ebay??
Old Jan 11, 2012 | 11:42 AM
TurboTodd's Avatar
The red seal thingy is part of the PS reservoir tank. Like I mentioned before you need a new tank as well.
Old Jan 11, 2012 | 11:47 AM
Yazz911TT's Avatar
The seal in the tank is fine tho. Its not damaged. I just need the red thing
Old Jan 11, 2012 | 11:54 AM
pwdrhound's Avatar
Unfortunately you need to buy the whole reservoir as Porsche does not sell just the red collar. I was in the same boat as my red collar was cracked. I was lucky as I ended up buying a used reservoir from a member here that had replaced his due to the valve TSB. His old reservoir was defective so I was able to buy it for $20 so that I could get the red collar off of it. If you have the GT2 conversion done already than you just need to buy the GT2 reservoir which is about $100 cheaper than the Turbo one. In the states the GT2 reservoir is about $500.
Old Jan 11, 2012 | 12:36 PM
Yazz911TT's Avatar
Ok but the red collar is not integral to the reservoir is it?? If not, then i can get some off my buddy, he has a few laying about!! thanks!
Old Jan 11, 2012 | 12:50 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
If your friend has a few you should ask were he's buying them from as I've seen guys have to spent big bucks as they broke there's as there is no option here to but just the rings.
Becareful with the stock gt2 hose as the angle to get it work is really extreme and I've seen them start to leak as you have to bend it really sharply and the trans moving under hard acceleration just increases the forces on the hard bend.
But congrats on getting the hose out!!
Old Jan 11, 2012 | 03:30 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Guys this is the situation I'm in!!! I'm distraught and literally in tears, this FFFFFFFFFF*****KINGGG BAAAA******RDDD will not COME OUT!!
I've tried drilling it, i've tried pliers, i've tried hammer and screw driver........I GIVE UP!!!
Superaudiofreak
Sep 4, 2015 03:22 PM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
Lucid Moment
Aug 20, 2015 02:22 PM
ppwchiang
Aug 20, 2015 10:28 AM
