Help. Please gt2 slave conversion shaft extension
Old Jan 15, 2012 | 03:39 PM
Talisman013's Avatar
Talisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond repute
I read a thread here that describes how to extend the slave cyl shaft for the gt2 conversion, but i cannot find it. Someone please link me.
Jayson
Old Jan 15, 2012 | 03:58 PM
the post described cutting and welding the gt2 shaft to the 996 salve cyl shaft. it had dimensions, etc...
Old Jan 15, 2012 | 04:02 PM
also, while I'm waiting, can someone who has done the gt2 master/slave conversion chime in on whether or not you like the spot it engages? If enough people say its ok, I may not do it. What I read was that it engages too close to the floor and that will this mod it will be closer to the center of clutch travel.
Old Jan 15, 2012 | 05:15 PM
John@SpeedTech's Avatar
Are you using a kit with the adapter bracket or doing it by tapping the case on the opposite side? The reason I ask is that if you are using a kit, I don't think you need to do anything to the shaft.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Jan 15, 2012 | 05:18 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Old Jan 15, 2012 | 05:58 PM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
Is making an adjustable rod in the cards? Would it be able to be removed and adjusted without it falling into the bellhousing? If so and the slave could be unbolted, the rod adjusted to make everything right.
Generally in a hydraulic clutch, the pushrod is ever so slightly shorter than the distance between the fork when fully disengaged and the fully retracted slave piston cup. Too much play and the release point will be quite low close to the floor. If the piston is slightly preloaded (not good) the pedal might be too high and 100% disengagement may not occur.
Old Jan 15, 2012 | 06:07 PM
thank you everyone. I used a dremel and ground the 996 slave shaft just like the gt2 shaft, now it pops in the slave and will not fall out. I can post a pic if anyone is interested.
Old Jan 15, 2012 | 09:24 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
Nicely done.
Old Jan 16, 2012 | 01:50 AM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
A pic would be appreciated, thanks.
Old Jan 16, 2012 | 06:42 AM
Yazz911TT's Avatar
Yazz911TT is infamous around these parts
Guys whilst on this topic again......Just thinking back to when I did this mod. I had an idea, i'm sure some one has thought of this already but maybe you could explain to me why it wouldn't work....So I was thinking...the reason for going GT2 slave....are 2...one is the feel and 2 is the consistent bite point.....the major problem causer is the luvly ACCUMULATOR, when looking at the set up i thought, why can you not just remove the accumulator and block the holes up with a bolt that will thread in to the 2 holes for the accumulator feed and return?? Surely thats cheaper and much easier than all this GT2 business?
John@SpeedTech
Sep 4, 2015 07:23 AM
gabe325
911
Sep 2, 2015 08:10 PM
