just finished gt2 master/slave install - Problem.
Old Jan 16, 2012 | 08:54 PM
Talisman013's Avatar
Talisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond repute
Finished install, bleed line with motive bleeder, all seemed to be going fine, pushed clutch for the 1st time, it snapped to the floor with zero resistance. I actually have to force the pedal back up.
Before I spend a ton of time troubleshooting, I figured I would check here.
Any ideas?
Old Jan 16, 2012 | 09:16 PM
VAGscum's Avatar
Any ideas?
Did you bleed the clutch system and pump it a bunch? It takes alot of pumping. You can't just hook the bleeder up and pop the bleeder on the slave and be done. You will have to pump it a bunch even with the power bleeder attached. If you bleed the system enough, than I would check for a puddle of fluid under the car.
Old Jan 16, 2012 | 09:20 PM
Fire's Avatar
Fire is just really niceFire is just really niceFire is just really niceFire is just really niceFire is just really nice
+1 on bleeding the system
Old Jan 16, 2012 | 09:25 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
Agreed crack the bleeder on the slave and make sure there's no air in the system. Your almost there
Old Jan 16, 2012 | 10:43 PM
Tim941NYC's Avatar
Oh yes, lots of bleeding.
Old Jan 17, 2012 | 07:49 AM
so let me see if i got this right, more bleeding?
Thanks,
Jayson
Old Jan 17, 2012 | 07:55 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
If not bleeding the rod may have slipped off the fork.
Old Jan 17, 2012 | 08:09 AM
Dr. Jekyll's Avatar
Dr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of light
Thanks,
Jayson
Yup, mine did the same thing. More bleeding will fix it. And when you think you're done, bleed it some more.
It's a pita to bleed because the reservour is so small. So after 30 seconds of bleeding you have to close the bleed screw, unscrew the power bleeder, add more fluid, reattach of the power bleeder, pump the pressure back up and then get back under the car for another 30 seconds of bleeding. Fun stuff.
Old Jan 17, 2012 | 10:06 AM
flavorPacket's Avatar
flavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond repute
Same thing happened to me. We ended up bleeding for about 15 minutes before everything turned out OK. That was 8 months ago, and I've had no problems since.
Old Jan 17, 2012 | 04:49 PM
Tim941NYC's Avatar
Pedal will get rock hard and not move.
Old Jan 19, 2012 | 01:50 PM
REVS11's Avatar
REVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond repute
A trick to bleed more efficiently is to stick your hand in through the inspection hole on the tranny and actually push the slave rod back into the slave, then open the bleed valve, close it again, and the release the rod. Keep doing it a handful times until you feel there's not "play" anymore in the slave rod (play = still air).
It's ten times faster and a lot less messy than bleeder, pedal, get under car again, push, air bubble somewhere refuses to get out etc etc.
Old Jan 19, 2012 | 02:12 PM
All done. I am now a lover of the GT2 Master/Slave mod. It feels great!
Thanks for the help.
Old Jan 19, 2012 | 05:06 PM
Tim941NYC's Avatar
Glad you enjoy it. It really changes the car.
Old Jan 19, 2012 | 05:10 PM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
Wait, I think you should get back in there and bleed it some more just to be sure.
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
Nissan GTR
Aug 19, 2015 02:11 PM
