75 mm intake setup recommendations
Old Feb 15, 2012 | 07:06 AM
jonty's Avatar
jonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to all
I am toying with doing the 75mm throttle body and y pipe setup. Who has the best pricing on a setup like this?. I like the AP (Cayanne) throttle body/plenum setup and was thinking of pairing with a speedtech y pipe. Any other suggestions?
Old Feb 15, 2012 | 07:17 AM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
no go with IPD and speedtech
Not sure you gain much though without doing turbos.
Maybe look at the 68mm set up
I have a Vivid Racing Y pipe and 74mm IPD works well but I only bought it for use with future Turbo Mods gains are not huge without i dont think.
Old Feb 15, 2012 | 07:18 AM
timccloud's Avatar
pics of my car and dyno sheets in shoot out more are in the garage if ur interested.
Old Feb 15, 2012 | 07:26 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
+1, OP... what other mods do you have?
Old Feb 15, 2012 | 08:53 AM
jonty's Avatar
Mods are umw stage 2a turbos, billet diverters, 997.2 gt2rs intercoolers, LWFW, clutch, gt2 clutch mod, evoms intake kit, AP intake box, europipe stage 2 exhaust. the ipd plenum I am not a big fan of and I would still need to get the throttle body as well.
Old Feb 15, 2012 | 09:04 AM
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
I have one of these never installed (went different direction if your interested? $ 500.00 + shipping
http://www.vividracing.com/catalog/#...5-p-86099.html
Old Feb 15, 2012 | 09:05 AM
MY996TT's Avatar
Just for curiosity, what size are those 2a turbos? With your setup, I guess the bigger TB and plenum will help. I have 75mm plenum, TB, and Y-pipe; I got them when SharkWerks parted out their "Great White". The plenum was custom made by Turbo Mike and the Y-pipe was one of a kind custom made too.
Old Feb 15, 2012 | 09:06 AM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
Interesting comments on the IPD
I have mixed feelings about mine also, after pressure testing, and having that thing leak from about every connection, I would prefer a welded part instead of the threaded connectors. The leaks were not very substantial, but they were present, and I did my best to address them short of removing the plenum from the car.
If I go to a larger TB, I may go with the Agency Power setup, however, it appears as if the AP setup does not retain all three of the stock Y pipe mounting points, which I prefer, but may be able to live without.
I believe there was some data showing an improvement in spool and power with K24/18g's, need to re-read those threads.
Old Feb 15, 2012 | 09:58 AM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
I have a vivid y-pipe along with an AP plenum and cayenne throttle body I am selling. PM me if interested.
Old Feb 15, 2012 | 10:24 AM
jonty's Avatar
PM sent
Old Feb 15, 2012 | 11:50 AM
johnspeed's Avatar
HI,I have been thinking about that mod.for awhile also.....Now,I am waiting for Todd from Protomotive to finish up on a modified stock Y-pipe to match up to the 74mm TB with a modified IPD plenum TimNYC gave me(I sent to get thermal coated) to do a dyno comparison with....As soon as I get all the parts in,I will be off to the dyno.....
Old Feb 15, 2012 | 11:56 AM
JSBear's Avatar
Keep us posted ..
I assume you are going to dyno before the install also ?
Old Feb 15, 2012 | 12:49 PM
johnspeed's Avatar
Of course,back to back on the dyno,Thats the only right way.....Going to switch it out on the dyno...
Old Feb 21, 2012 | 12:51 PM
johnspeed's Avatar
HI,Just got my Modified stock Y-pipe, match up to the 74 mm TB, from Protomotive...It looks great...Have everything now,the thermal coated IPD plenum came in.....Now to call a dyno shop to let me do the back to back switch on there...Can not wait.....
Old Feb 21, 2012 | 01:04 PM
JSBear's Avatar
Looking forward to the results.
I'd like to shift my torque curve around 400 RPMS to the left.
