997 shifter mod
Old Apr 1, 2012 | 04:50 PM
r71's Avatar
r71
r71 has a spectacular aura aboutr71 has a spectacular aura about
997 shifter mod
My first mod is going to be the 997 shifter. The previous owner installed the B&M SSK and had problems ever since. Apparently the shop who installed it didn't follow instructions and marked/count the notches of the original position of the 2 cables. Since I don't know the correct position, is there a way to do this with just the alignment tool that holds the shifter in the neutral position?
Old Apr 1, 2012 | 11:35 PM
pwdrhound's Avatar
The 997 or 997ssk both come assembled and are sold with the alignment tool from Porsche included.
Old Apr 2, 2012 | 02:29 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
The install takes time but isn't that complicated. Mike Kelly did a complete dyi on it. Seach in this forum. While you've got the consol out, get a PCNA rocker switch and wire your garage door controller to it. Change the motor mounts and tranny mount while you're at it and you'll think you're driving a different car.
Old Apr 4, 2012 | 07:34 AM
r71's Avatar
r71
I read the DIY and it does seem straight forward. My only problem is the previous owner installed the short shifter incorrectly. He didn't do the marking of the cable and counting the thread.
My question is, is there a way to get the right position if I don't know the right position to start with???
Old Apr 4, 2012 | 09:12 AM
r71's Avatar
r71
It's in. I hope using the tool, the cables lined up ok. Took it out for a spin and it does feel much tighter. I'm still having intermittent issues going from neutral to 1st. Once in a while it doesn't seem to engage all the way. It grinds so I have to shift out and reengage. Anyone having this issue?
Old Apr 4, 2012 | 09:30 AM
pwdrhound's Avatar
I've swapped a B&M shifter for the 997ssk. Contrary to popular belief, it's not the counting of the threads that important because how do you know the previous shifter was rigged properly or how do you know that the new shifter will mount up in the exact same spot as the previous one due to the play in the mounting lugs, manufacturing tolerances, etc. If I recall correctly, with the transmission in neutral, the cables are spring loaded to the neutral position. The key to a proper rigging is to bolt in the new shifter assembly and MAKE SURE you have the Porsche centering tool attached to the shifter assembly to ensure you are dead center. After that it is a simple matter of clipping the cables into the threaded portion of the assembly and sliding the spring loaded retainer clip in place. Finally, remove the centering tool from the shifter and you are done. Fwiw, when I installed my 997ssk shifter the cables ended up about 2 or 3 threads off from the previous B&M assembly. As a side note, even though the B&M assembly is based on a Porsche part you can not use the Oem centering tool with it so rigging it properly is tricky.
Old Apr 4, 2012 | 09:45 AM
pwdrhound's Avatar
Grinding is not normal and may indicate some type of damage. I would first change the fluid and see if you see a difference. I used the Oem mobilube ptx 75w90 which is only available through the dealer. Shell transaxle 75w90 is another Oem fluid your dealer can get. The shell is available in 1qt bottles...
Old Apr 4, 2012 | 09:50 AM
r71's Avatar
r71
What you described is exactly how I installed. Although the neutral cable was literally 1/2 mm short. Meaning I had to pull the cable ever so slightly to clip in. Feels tight!
Old Apr 4, 2012 | 09:51 AM
r71's Avatar
r71
I'll give that a shot.
Old Apr 4, 2012 | 12:29 PM
Simi_996's Avatar
Simi_996 is infamous around these partsSimi_996 is infamous around these parts
1st will be a little harder to get in esp in the cold.
Old Apr 4, 2012 | 02:31 PM
r71's Avatar
r71
User error!!! I just didn't know how to drive! I wasn't used to clutch catching high. It's got a on/off racing clutch so it's a little difficult. After I get going I was only pressing the clutch peddle 2 - 3 inches to change gears. It was all that was needed because it caught really hight with very small window. When going into first, I started to press it all the way down. Now the grinding is gone. Maybe I wasn't pressing the clutch peddle enough to engage. I might me jumping the gun, but I think that was the problem. I'll report back tomorrow. Premature whoohooo!
Old Apr 4, 2012 | 02:32 PM
r71's Avatar
r71
But yes, you guys were correct. The 997 clutch is much better. I'm going to tell all my porsche buddies to do the mod. It was so easy.
Old Apr 5, 2012 | 10:31 AM
cab2u's Avatar
cab2u is infamous around these parts
I have the same problem from neutral to 1st. Had it before and after the upgrade to the 997 shifter. I had brought to the dealer when it was still under warranty. They said there was nothing wrong. Hasn't been a problem, just an annoyance. I would love to know if there really is something wrong.
Old Apr 5, 2012 | 10:33 AM
r71's Avatar
r71
It's definitely much better now. I'll just have to get used to it I guess.
pnoob2
Oct 31, 2015 06:34 PM
orbelo
Aug 30, 2015 12:26 PM
TrackOne
Aug 20, 2015 12:56 PM
HolmaN
Aug 19, 2015 07:32 PM
