Another K16 billet build
Old Apr 13, 2012 | 08:25 PM
  #61
SamboTT@ByDesign's Avatar
Prodigy you are pretty happy with your inter-coolers huh?
I am going to try and get some ordered. I like the .2's (thanks earl3) and those best depending on requirements.
Old Apr 13, 2012 | 10:39 PM
  #62
jonty's Avatar
jonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to all
I asked Scott several times about the second pump and was told each time that for my current levels I didn't need it.
Old Apr 14, 2012 | 08:37 AM
  #63
jonty's Avatar
Prodigy I just upped the feed jet 30%. I am going to log again Monday , if I send the log to you can you graph again?
Old Apr 14, 2012 | 09:18 AM
  #64
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
you should log the duty cycle, that would give you the answer as to if you have enough fuel or not.
Old Apr 14, 2012 | 12:11 PM
  #65
jonty's Avatar
Will do
Old Apr 18, 2012 | 05:55 AM
  #66
jonty's Avatar
Well I picked up the car today and on the first highway pull with the shop owner in 4th gear the clutch let go LOL . The clutch is a UMW LWFW stage 2 organic setup with less than 2k gently driven miles on it. Went back to the shop and a ceramic multi puck stage 4 from EVOMS is going in tomorrow. The good news is it validates the power as kevin had said the clutch was 700hp rated.
I do have a log before the clutch went out I will post up later, I upped the meth injection amount and Injector duty cyle is about 85% max with 1000cc/min of meth injection at that point
Old Apr 18, 2012 | 06:39 AM
  #67
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
what is b6 intercooler ??? as well as how much boost you are running with / with out meth injection ???
thanks alot its look like good project
Old Apr 18, 2012 | 06:41 AM
  #68
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
So let me get this straight you are running stock injectors & a 5bar with only a stock fuel pump?
If so I call BS on your guesstimate whp.
Stock injs w/5bar would be less than 600whp.
So the best way to determine your cars power would be do some 60-130 times.
I would not presume the used clutch estimate of 700 crank HP is an accurate one.
Old Apr 18, 2012 | 07:34 AM
  #69
jonty's Avatar
" I call BS on your guesstimate whp.
Stock injs w/5bar would be less than 600whp."
I would not presume the used clutch estimate of 700 crank HP is an accurate one."
I am not calling any estimate on WHP as I have know idea what a 1000cc/min of 50/50 water meth does to the fueling? , the clutch was brand new to me not used I had just driven it on the old UMW stage 2a kit for 6 months.
I am saying its making a lot more power and blew through my uprated clutch which I think is a rally good sign. So no need to call BS.
I am really not worried what the WHP is
I agree 60-130 tells the truth as soon as I get the clutch in and can get some times I will, I do think WHP will be round 600 given the extra fuel I am getting from the meth, but who knows.
Old Apr 18, 2012 | 07:36 AM
  #70
jonty's Avatar
B6 = Blownsix
Fail safe is 1 bar (no meth)
with EBC and Meth I run 16 psi or 19psi
Old Apr 18, 2012 | 07:44 AM
  #71
jonty's Avatar
Log
Old Apr 18, 2012 | 08:34 AM
  #72
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Did you wake up on the wrong side of the bed today? Go get some coffee.
Old Apr 18, 2012 | 08:54 AM
  #73
You have a magic dyno there my friend. There is no way you are making 700/780 with your fueling on 16/16's. Go run some times to back those numbers up. I had 2 pumps, 60lb injectors and EVERY supporting mod known to man with my 16/16's and I never dyno'd over 550 on a dyno jet. But it was a tip and they don't dyno well. But, I was not much over 600 if at all.
Old Apr 18, 2012 | 12:19 PM
  #74
RxPorsche's Avatar
RxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud of
Thumbs up
Nice dynos #s jonty . I'm going with k24 billet and your 997 gt2RS intercoolers (literally you know). I'm really thinking of doing a meth install but going 100% meth to see what numbers the car get. Enjoy in good health .
Old Apr 18, 2012 | 01:23 PM
  #75
jonty's Avatar
I agree the dyno is High as I have always stated
