Jacking points
Old Apr 30, 2012 | 12:58 PM
Kerrage's Avatar
Kerrage is a name known to allKerrage is a name known to allKerrage is a name known to allKerrage is a name known to allKerrage is a name known to allKerrage is a name known to all
Jacking points
Hey Guys,
Where is the best place to jack up the car at the rear so I can get two jackstands under so that I can remove bumper and change exhaust....(I think bumper has to come off to install exhaust?
Old Apr 30, 2012 | 01:03 PM
bushman66's Avatar
bushman66 is infamous around these parts
Here is what I do to lift the car. I use a small floor jack on the rear pass side jack point allowing me to get my large floor jack far enough underneath to jack on the chassis cross member about 3 feet in. Jack on that point, set a jackstand under each jack point. Piece of cake...
Old Apr 30, 2012 | 01:10 PM
Kerrage's Avatar
ahh K I think it will make sense once I am under the car..I just dont want to bend anything....TOo bad someone didnt have a pic on here?
Old Apr 30, 2012 | 01:13 PM
bushman66's Avatar
You'll see the cross member when you are underneath. Some guys advocate jacking on the boss cast into the engine case, but IMHO, the motor mounts weren't meant to carry that kind of load...I just throw a hockey puck onto the jack cradle and it works perfectly...
Old Apr 30, 2012 | 01:29 PM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
Some good info and pictures here
https://www.6speedonline.com/forums/...bolt-mods.html
Also do a search there is tons of info on the subject
Old Apr 30, 2012 | 10:11 PM
Kerrage's Avatar
I think this pic says it best...Thanks guys for your quick response!
Old Apr 30, 2012 | 11:36 PM
bushman66's Avatar
That's the crossmember...good luck!
rangerdick
Nov 5, 2015 11:11 PM
fjwheeler
Sep 19, 2015 10:56 AM
dc2000
Sep 16, 2015 11:53 PM
Goonie
Sep 12, 2015 02:10 AM
porsche42
Sep 4, 2015 08:21 AM
