Vertical Hedalight Adjsutment
Old Jun 13, 2012 | 11:20 PM
Turbo Fanatic's Avatar
This is simple enough per the manual. Anyone know what size hex wrench fits?
I have a whole set of long ones....
Old Jun 14, 2012 | 10:18 AM
Slider's Avatar
OK, I think you're talking about the hex wrench to remove the headlight assembly from the car. Just try a few and use the one that works. I'm pretty sure the vertical adjustment internally is just a Phillips screw - it's been a long time since I adjusted mine.
Old Jun 14, 2012 | 11:39 AM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
i'm thinkin 5.5 or 6mm hex, but some do have the + also for a phllips
Old Jun 14, 2012 | 12:08 PM
i've been wanting to adjsut mine. my car is lowered and i want to point them a bit higher. where is the adjsutment on the light?
#TeamAIM
Old Jun 14, 2012 | 03:38 PM
Slider's Avatar
You have to remove the assembly from the car. There are two screws to adjust - one for vertical and one for horizontal. You are actually moving the whole auto-levelling mechanism when you adjust the screw for up and down.
Old Jun 14, 2012 | 07:35 PM
jayzbird's Avatar
jayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to behold
No need to remove the headlight. You need a LONG 5 mm. Griot's sells a set that's long enough. Oh, and my 03 manual had the up/down rotation backwards.
Old Jun 14, 2012 | 07:56 PM
DERBOOST's Avatar
And you can jack with your foglights as well, thats the frontmost hex. Ba aware as well that its not such a bad idea to pull the headlight and clean/lube the adjustment assembly. Its made of nylon and can strip real easy if gummed up.
rob4wellness
Oct 2, 2015 07:32 AM
embdenb
Sep 30, 2015 09:27 AM
BLKMGK
Sep 19, 2015 03:51 PM
BLOWN SRT
Aug 25, 2015 01:28 AM
Al Norton
Merchandise For Sale / Wanted
Nov 6, 2006 07:40 PM
