Aquamist HFS-3 - DIY
Old Jun 26, 2012 | 02:08 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
Really want to do an Aquamist setup on my car. Just curious how difficult the install is, I've installed a double din radio, spark plugs & coils (bumper removal method), oil sender, replaced check valves (lowered engine), N75, Bypass valves, have had the y-pipe / TB out etc. etc.
Is this in the same difficulty range ?
Pretty good write-up here, not sure if there are others ? http://www.impconcepts.com/porschetu...stallation.htm
What size nozzles would you recommend for K24/18g's.
Car is not my daily driver, so downtime is not a big issue. Would work with Protomotive upon completion to adjust my tune.
Any advice is appreciated.
Old Jun 26, 2012 | 06:25 PM
jonty's Avatar
jonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to all
Go to the Aquamist forum they have great support there.
Old Jun 26, 2012 | 09:07 PM
awdbiturbo1's Avatar
awdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant future
off topic question, But on the aquamist kits are there any markings on the nozzles to know what size you have? Also has anyone experiment with larger nozzles?
Old Jun 27, 2012 | 03:17 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
yes , nozzeles will have color
http://www.urdusa.com/images/aquanoz.jpg
, am running 2 big nozzles in my setup
Old Jun 27, 2012 | 12:01 PM
I ran two 1.0mm nozzles with my setup. Worked gooood
#TeamAIM
Old Jun 28, 2012 | 11:06 AM
ShokWaveRider's Avatar
ShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to all
Hi: I am the author of the DIY above, Thanks for the credit... The Nozzles are NOT clearly marked, but have a color coded ring on them which is supposed to designate a size, but the only way I have found is to go by the sticker on the packet. Some have an 8 on them but that is the thread size 8mm.
I have helped lots of folks do this it is a great mod and it reduces in cylinder temperatures dramatically.
Let me know if you have any questions. If you look on the website where the injection write up is, you can see all the mods I have done.
I use 1mm for all applications and ajust the map of the controller for different applications.
Ian
therock88
Jul 14, 2018 11:22 PM
ECS Tuning - VW
Sep 30, 2015 03:11 PM
gliozzi
Bentley
Sep 28, 2015 03:27 PM
NRoy7
Sep 19, 2015 06:59 AM
HIX
Sep 8, 2015 03:16 PM
