Some pics of my engine build...
Old Jul 3, 2012 | 09:39 PM
Tim941NYC's Avatar
Here are some pics for you to review and enjoy.
Case
Gt3 pump and turbo IMS
Turbo IMS
Turbo crank and Carrillo rods
Ready to install jug
jug on ring compressor removal
this should be in front of one above. Install of wrist pins and clips of outer cylinders.
Pressing in the center sleeve.
Sleeve installed
Head on with (top secret stock head gasket and raceware studs) look at those exhaust ports..
Intake ports
No vario cam
Old Jul 3, 2012 | 09:59 PM
johnspeed's Avatar
Hey Stupid Question,,,Do they make a straight cut gear set-up for the crank / cam drive gear asembly??..I believe if they did ,you would have installed that..
Old Jul 3, 2012 | 10:00 PM
UrbanHotrod's Avatar
UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !UrbanHotrod Is a GOD !
Tim, looks great! Only a few thing left and your up and running. Man the porting looks great. Who did it? Those Presicion turbos are gonna love this motor!!!! Keep the info coming.
Old Jul 3, 2012 | 10:07 PM
Tim941NYC's Avatar
Yes they do John. They make plenty of noise for little if any gain. The only real thing it does is not add side load on the thrust bearing on the ims. Not really the big a deal.
Old Jul 3, 2012 | 10:19 PM
Tim941NYC's Avatar
I do almost all my own work. Believe it or not those are factory with a little brushing up. These heads flow 50cfm more @.400 lift intake and 45 cfm @.400 exhaust then my last setup.
Old Jul 3, 2012 | 11:00 PM
m3ntal's Avatar
Senior Member
m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !
Nice Tim. Yous a beast. Can't wait for the show down between the master and his student
Old Jul 4, 2012 | 12:13 AM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Badass Tim, your an artist when it comes to the p-cars.
Old Jul 4, 2012 | 01:05 AM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
Does the the oil pump need to be clearanced for the Carrillos? Or are they plug and play?
Nice work, I'm looking forward to watching your build progress.
Thanks again for the help.
Old Jul 4, 2012 | 02:12 AM
machinegunt's Avatar
machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !
Very nice pics! Thanks for sharing them! :-) Subscribed!
Old Jul 4, 2012 | 04:38 AM
jpflip's Avatar
TIM!!! Do I have to tell you I love this post!!!!!! Thanks!!!! Very nice work!
Just did an inspection of you head and would like to know what are you planning to do with this four inches crack!!! LOL!!!
Old Jul 4, 2012 | 06:56 AM
Tim941NYC's Avatar
Thank you. Yes the oil pump needs to be clearanced. Very little today though, I feel because of the 4.0 motor, the newer pumps are cut more from the factory. The gt3 rod bearings diameter is smaller then the turbo one this is do to the extra load from the torque that the turbo makes.
Old Jul 4, 2012 | 07:01 AM
Tim941NYC's Avatar
Keen eyes.. Its a hair from....
Old Jul 4, 2012 | 07:08 AM
jpflip's Avatar
Just curious. You did not installed any vario cam system for advance and it seems that the cams did not have the dual lift system??? Is it possible? You will have to modify the ecu programming I guess? How about the tappets, did you installed a solid ones?
Old Jul 4, 2012 | 07:11 AM
Tim941NYC's Avatar
Some more....
Stock piston cut for new valves. Thanks Pumptech for the pistons!
lifter buckets
lol
Old Jul 4, 2012 | 07:19 AM
Tim941NYC's Avatar
MoTec... no dual lift. no vario. no factory ecu control the motor any longer. I feel that on the factory race cars there is no high lift and no vario. maybe because the weight? That there is to much to break? Not much in the low lift and the vario but emission value? I will find out..
