Rim & tire combo
Old Jul 4, 2012 | 03:40 AM
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
Rim & tire combo
Which rim & tire combo shall I go for if I decide to go for a set of 19"?
8.5J ET53 front & 11J ET45 rear with 235/35/19 & 295/30/19 or 8.5J ET53 front & 12J ET51 rear with 235/35/19 & 305/30/19, 315/25/19 or 325/30/19
Appreciate your thoughts.
Thanks Joe
Old Jul 4, 2012 | 11:25 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
The 315/25/19 setup is ideal because it does not increase the diameter of the wheels significantly over the 18's, however they are out of production and are difficult to find.
The other options are taller. The 295 option might make your car oversteer a bit because you are increasing the width of the front and not the back. I would probably go with the 305 option, it might be the most balanced compared to stock specs.
Old Jul 5, 2012 | 03:20 AM
dragonman4's Avatar
dragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond repute
As long as your overall diameter and revs per mile are within spec, you should be fine. Any taller than 26" I think and you might have an issue with rubbing.
Refer to this.
https://www.6speedonline.com/forums/...ire-se-up.html
we should probably sticky that thread since it seems to be the one all the tire threads go back to.
Old Jul 5, 2012 | 11:12 AM
03 996tt's Avatar
03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future
Always wondered what the "J" means on the width measurement. Anyone?
Old Jul 5, 2012 | 11:28 AM
pwdrhound's Avatar
The "J" refers to the shape of wheel lip or flange the tire bead seals up against. This goes back to when steel wheels had rolled mounting flanges.
tstat
Feb 7, 2026 06:12 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
richard181
Bentley
Sep 9, 2015 01:53 PM
Aug 19, 2015 06:35 PM
