What To Do Whilst The Engine's Out?
Old Jul 8, 2012 | 08:03 AM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Thinking about taking my car to the garage to get the engine pulled
What should I do whilst it's there?
I'm thinking......
Clutch
Turbo Inlet Pipes
Welded Coolant Pipes
Injectors
Is there anything else I should do, and can the injectors be done one a car which is otherwise stock
I don't have the funds to do my turbos and everything else right now, but I thought it'd make sense to do the injectors whilst the engine's out if I can do so without having to go all out straight away
Old Jul 8, 2012 | 09:51 AM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
These might be worth looking at and shouldn't break the bank:
Plugs/coils, engine/tranny mounts, coolant overflow, coolant lines
Old Jul 8, 2012 | 02:39 PM
NBTBRV8's Avatar
NBTBRV8 is just really niceNBTBRV8 is just really niceNBTBRV8 is just really niceNBTBRV8 is just really niceNBTBRV8 is just really nice
Idler pulleys.
Old Jul 8, 2012 | 04:03 PM
Valley996TT's Avatar
Valley996TT is just really niceValley996TT is just really niceValley996TT is just really niceValley996TT is just really nice
Plenum
Old Jul 8, 2012 | 07:14 PM
deckman's Avatar
how long does it take to pull the engine?
Add Content
Old Jul 8, 2012 | 07:59 PM
John@SpeedTech's Avatar
The 2nd gear detent by Gbox is a good upgrade and easier with things out.
Also, GT2 clutch conversion is much easier with the motor out and another great upgrade.
I would also replace all the rubber coolant lines on the motor.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Jul 8, 2012 | 08:24 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Go on vacation. Play some golf. These are good things to do while engine is out.
Old Jul 9, 2012 | 06:00 AM
deckman's Avatar
What does it cost to drop the motor?
Old Jul 10, 2012 | 06:42 PM
Tim941NYC's Avatar
Send it to me
Old Jul 10, 2012 | 10:30 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
5 Bar FPR for turbo upgrade.
Clutch to hold the power you want.
Water pump.
Old Jul 11, 2012 | 08:13 AM
n360rb's Avatar
n360rb is a jewel in the roughn360rb is a jewel in the roughn360rb is a jewel in the roughn360rb is a jewel in the rough
Was talking Chris Green at USP. Said he almost every TT that comes in the transmission mounts are bad. I checked mine...and they are bad. Will replace mine soon.
Old Jul 11, 2012 | 05:27 PM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
Maybe the oil pressure sending unit along with all the fore-mentioned components. Especially those coolant fittings and hoses.
Old Jul 12, 2012 | 10:35 AM
Mike in MD's Avatar
Mike in MD is infamous around these parts
Just had mine out DIY, aside from upgrades my list for maint/reliability/future-proofing:
-Coolant Expansion Tank
-Water Pump
-Pin, not weld, glued coolant connections
-Oil Pressure Sending Unit
-Plugs, Coils, Bosch DV's
-All the metal turbo oil feed/return lines (If you ever plan to change your turbo's in the future and they corrode/freeze/strip, it's engine out to replace any one of the 4)
-Motor mounts (I went UMW 964)
-Rubber turbo wastegate vacuum lines
-Trans mount (997)
-5 bar Fuel Pressure Regulator (really a mod, but might as well do it if you plan bigger turbo's/chip...it's relativly cheap)
-New o-rings for the "snap-in" intercooler/coolant lines.
As a mod while the engine is out you might want to consider the GT2 trans mod/conversion. Need to drill the case to move the slave but it can't be done with the engine in. Since you will also need to modify the PS pump, it will already be out of the car during engine removal, saving future time. Also way easier to remove the unused PS pump to trans supply lines when the engine is out. One of my favorite mods so far.
Inspected all of the rubber hoses and chose not to replace them as they were still solid/flexible. Hope to not regret that decision.
FWIW
Jul 29, 2019 11:13 AM
EMC2
Cayenne 955/957
Sep 7, 2015 05:20 PM
vr6tee
Aug 29, 2015 03:52 AM
The Oss
Aug 24, 2015 08:19 PM
