Big turbos - inlet intake pipe (fender intake)
Old Jul 13, 2012 | 07:36 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
speeders , when i took out my 997 turbo garret GT3076 fender intake pipe , i noticed its smaller than the comprosser wheel inlet housing !!
so i Measured the intake pipe it was 2.6'' and the comprosser wheel inlet was 3'' !!!! so is it bad running a intake pipe smaller than turbo inlet housing ????
i would like to know guys who are running GT30s , GT35s , a3076 what size you are running for intake pipe ???
i asked in 996tt forums because many of you running big turbos
thanks in advance ..
Yousef
Old Jul 13, 2012 | 07:46 AM
i used 2.5" inlet pipes. dont think bigger will fit back there. unless you do fender intakes.
#TeamAIM
Old Jul 13, 2012 | 07:57 AM
ysfg35's Avatar
yes i was talking about fender intake
BTW, congrats about your awesome car bro
Old Jul 13, 2012 | 08:45 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Mine are 3".
Old Jul 13, 2012 | 09:02 AM
Originally Posted by BlackHorseTurbo
Mine are 3".
Mine are bigger
#TeamAIM
Old Jul 13, 2012 | 09:06 AM
Tim941NYC's Avatar
I had 3'' from the turbo up to the the back of the motor then went to 3.5'' right to the maf. I would think it hurts but only one way to really find out. I dumped the maf and the stock ECU for that matter. moved the turbos too, no fender intakes here.
Old Jul 13, 2012 | 09:09 AM
unvmy996's Avatar
Yousef
i think mine are 3 in aswell but im not 100% sure, to be honest with you i really dont think theres a difference , or you would notice a difference between 3in and 2.6in.
either way it still better then stock
Old Jul 13, 2012 | 09:29 AM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
Mine are 3" all the way to the top. It does not make that big of a difference though with that extra .4". Most setups that are 3" are flattened in areas to make room for the tires. I remember seeing Scott's White GT2 having it done and a few other Proto setups. Justin had to do the same on his car when he did them on the ORIGINAL test Boost Logic kit, but when mine was built (the "production" kit) there was a lot of time spent to tuck up against the frame rail. It is a VERY tight squeeze back there, but in the end .4" isn't going to hurt you at all for power, nor will you gain any by getting that extra .4"
Old Jul 13, 2012 | 09:50 AM
ysfg35's Avatar
got the point , thanks alot guys for your help
Old Jul 13, 2012 | 10:14 AM
Mine are bigger
Jun 10, 2017 07:45 PM
MurderedTurbo
Aug 28, 2015 09:06 AM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
HolmaN
Aug 18, 2015 01:35 PM
