New 710n diverter valves honking
When do they honk? Is it only under boost or all the time? I'm hearing a honk at .1 bar, typically at cruising speed (75mph) only under slight acceleration. I'm wondering if I have the same problem.
They make a slight sound when releasing the throttle, but make a big honk or continuous honk as boost comes on. I took the car to the track this past weekend and at this one particular turn while on maintenance throttle, there is a continuous honk. I thought I read that honking diverter valves are a sign that they are bad, this set is brand new.
Sounds very familiar. I know that I have aftermarket DVs, but I don't know which brand. They appear to be black plastic, but I can't get a good description without removing hoses. I'm bringing my car to the shop on Friday to have it checked out. I'll let you know what they say.
The DVs should be silent. Something is not right. FWIW, I have the Baileys DV30 valves and they are silent and 100% maintenance free. No issues whatsoever....
DVs will honk if you put them in backwards. check...
#TeamAIM
#TeamAIM
2nd this.
Also is everything else normal? After my 710Ns went in I had some honking but was also losing boost/performance because a vacuum hose had popped off somewhere. Once that was remedied, everything else was fine.
This was done at a nationally known turbo shop so they should know better, but I will check it out.
this is what DVs sound like backwards...
#TeamAIM
#TeamAIM
That sounds like more of a whistle in the video. Mine sounds like a faint horn going off in the trunk. More of vibrating air that is constant. The sound I hear is when I give throttle, not when I let off the throttle.
To be honest at first I thought the noise was the rear tires rubbing on the fenders (the car is slammed) because it was this odd noise... not like a BOV or anything like that.
