Spark plugs no good?
Old Jul 26, 2012 | 10:28 PM
ek9max's Avatar
ek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud of
As of late I have had some hesitation at WOT..... starts at about 4500. And seems to clean up at about 6000.....
Is this a common symptom of spark plug change?
I have NGK iridiums BKR7EIX gapped about about .28 if I recall correctly.
Alpha3076 with both ons at about 1.2-1.3 bar.
Thanks in advance!
Old Jul 26, 2012 | 11:21 PM
Engine Guy's Avatar
Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !
The plugs are great plugs and usually work well in bosted applications. What does your durametric tell you? Any particular cylinder? You could always change them out for some fat wire plus to find out. They are super cheap, the only thing that hurts is the labor for you.
Old Jul 26, 2012 | 11:57 PM
ek9max's Avatar
I haven't done any durametric logs yet. What parameters should I be logging to look for this?
Old Jul 27, 2012 | 02:27 PM
ek9max's Avatar
Just went for some runs with the durametric to see which cylinders were misfiring. After a few hard runs it seems to have stopped misfiring....
Could it be that because I usually drive like a grandma the plugs got dirty? Then after the runs they cleaned up?
Old Jul 27, 2012 | 04:20 PM
evil 996tt's Avatar
evil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud of
If you removed your IC's for the plug change, check the connections, it could be a minor boost leak
Old Jul 27, 2012 | 05:11 PM
ek9max's Avatar
I didn't change them yet. Car seems to be running great after some hard pulls.
Old Aug 4, 2012 | 03:55 PM
ek9max's Avatar
Pulled my plugs today. They are 0.030 or bigger.
I'll try to get some fresh ones in there at 0.025. I bet that will solve my misfire.
Old Aug 4, 2012 | 11:33 PM
SamboTT@ByDesign's Avatar
Do that and you will be fine. Enjoy it!
Old Aug 4, 2012 | 11:54 PM
ek9max's Avatar
Did a couple runs tonight. No more misfire!
audipwr1
Sep 25, 2021 01:31 PM
RallyBird
Oct 7, 2015 01:20 PM
away
Sep 4, 2015 12:30 PM
LiquidElephant
Aug 27, 2015 06:17 PM
Highlander
Aug 23, 2015 09:05 PM
