Shifting noise?
Old Aug 31, 2012 | 08:45 PM
JayAndreTT's Avatar
JayAndreTT is just really niceJayAndreTT is just really niceJayAndreTT is just really niceJayAndreTT is just really niceJayAndreTT is just really nice
Shifting noise?
So I installed a 997 ssk in a few months ago and it's been great. I've noticed though that it clicks when you go into gear. It's not too loud, it's as if you're flicking a light switch quickly. The mechanic said there's nothing wrong with it. Any ideas?
Also, when I shift really fast from 1st to 2nd, I notice that in the back of the car I feel like a big pop or something. It's like I'm really feeling the gearbox work. Is this normal?
Old Aug 31, 2012 | 11:36 PM
code7rpd's Avatar
code7rpd has a spectacular aura aboutcode7rpd has a spectacular aura about
I had a light click and found the shifter cable was binding slightly. The stock shifter has a green plastic clip on the bottom that the 997 ssk does not although it has a a spot for this clip. I put the clip from the stock shifter on then ssk causing the cable to bind a little making a clicking sound. After removing it, the noise went away.
BenTT
Jul 22, 2021 02:38 PM
Bmanny
Sep 16, 2015 08:29 AM
dailydriver
Sep 13, 2015 09:01 AM
Yogi911
Sep 9, 2015 08:20 PM
andbos
Sep 7, 2015 07:13 PM
