Front strut mount failure - upgrade recommendations?
Old Sep 25, 2012 | 09:01 PM
pureporsche's Avatar
pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !
So after a very eventful trip from Vancouver (Canada) to San Fran, up through Yosemite, Central Oregon and back; mid way my front left shock mount (I think it's the mount) gave in. Not sure if it's the bearing or the hat, or both.
I managed to save the trip by limping along, but now that I'm back I'm wondering what recommendations to aftermarket parts are out there, for AWD Turbo obviously.
Is any one using any camber plates instead (Tarett?)? Any info and first hand recommendations would be beneficial before I embark on doing some of my own research.
Old Sep 25, 2012 | 09:03 PM
Image showing the failure - upper left shock, showing threaded upper piece penetrating straight through.
Old Sep 25, 2012 | 09:26 PM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
I have the Tarett and i am happy with them, i had a problem when i received them but Ira as an exceptional customer service and sent me the replacement part no problem.
I don't know how they would work with stock suspension though, my suspension is all modified and custom so can't say.
Old Sep 25, 2012 | 10:07 PM
Hi Pumalex... Thanks!
I'm not running stock suspension either.
Curious - are the tarett mounts a direct replacement for the bearing and the boot (plastic/rubber mount)?
Old Sep 26, 2012 | 04:37 AM
pumalex's Avatar
well on my car it replaces everything and the top plate that holds the spring on the coilover is the last needed part from the coilover.
i'll try to see if i have some pics at home.
Old Sep 26, 2012 | 11:13 AM
pumalex's Avatar
here it is with my Moton
Old Sep 27, 2012 | 07:25 AM
Rep given - thanks pumalex!
Old Sep 27, 2012 | 08:07 AM
rmc1148's Avatar
Pureporsche if you dont mind me asking how many miles did you have on car at time of failure and did you track it.
Old Sep 27, 2012 | 08:27 AM
84k km (45k miles) on it when it failed.
I do track it, but not in the last two years, so wouldn't think that had anything to do with it.
It started to become very apparent (clicking noise and then loud clang-metal-on-metal noise) as I made my way down south on the twisties to San Fran (Oregon coast), with steering becoming very lose.
Any one who has driven that stretch of tarmac knows the down elevation to incredibly tight left hand turns with steep concaves, switching to up elevation changes, that could easily be putting multiple G's of force on the left front corner of the car. That said - it was all within normal driving dynamics (not pushing the car to LeMans 24hr endurance levels, LOL)
Most likely it may be an install problem, actually I'm kinda thinking it may be...
Here's what the experts say at Tarett (without seeing anythng more than the image above): "It's rare for the mount to fail like that, and makes me wonder if the struts were installed properly. There is supposed to be a large washer on both sides of the rubber mount, and I suspect that the lower one might be missing. When you remove everything, you can send me a picture and I will let you know if it was installed correctly."
I'll know today - having the strut pulled out and examined.
Old Sep 27, 2012 | 08:32 AM
pumalex... have you noticed any additional cabin vibrations with the camber plates? And what camber are you running on the front/rear?
Old Sep 27, 2012 | 06:16 PM
pumalex's Avatar
hard to tell as i am solid on pretty much everything on the car so it is a harsh ride can't say it's because of the top plates though. I have GT3 OEM in the back which are also solid.
I kinda of gave up on having a smooth ride, i beleive the springs of my coilovers are making all the noise because a friend has the Tarret plates like me and his car is more quiet.
Old Sep 27, 2012 | 10:17 PM
Awesome thanks.
BTW: turns out that the problem was an incorrectly fitted spacer (when the Bilstein strut failed and was replaced under warranty a month ago) that led to the failure - my mech shop is repairing, and took ownership of the "spacer-mistake".
...So looks like Ira (@ Tarett Engineering) called it right!
Old Sep 28, 2012 | 04:29 AM
32krazy!'s Avatar
+1 for the shop stepping up. dont see that very often
Old Sep 28, 2012 | 05:15 AM
pumalex's Avatar
Yeah Ira knows his stuff, best customer service i know of, also responds quicly to his e-mails.
Old Sep 28, 2012 | 07:26 AM
Yeah, hands down best mech shop in Vancouver, Canada... a little pricey but top notch! Have had a relationship with them for well over 10 years and two porsches.
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
