Who made the best Diverter Values
Old Oct 26, 2003 | 01:09 AM
toffeGT2's Avatar
toffeGT2 is infamous around these parts
Question Who made the best Diverter Values
I am thinking to replace those diverter Valves on my GT2 to eliminate those Honking sound, but there are several brand around in the market, which one good? Can someone recommend?
Thanks.......
Old Oct 26, 2003 | 02:36 AM
Crash's Avatar
Crash is infamous around these parts
Diverter valves
Choose either Bailey or Evo. You can´t go wrong with either.
Old Oct 26, 2003 | 06:20 AM
Cingulum's Avatar
Cingulum is infamous around these parts
Are you experiencing a loss of power/boost?
Old Oct 26, 2003 | 10:11 AM
TCM's Avatar
TCM
TCM is infamous around these parts
I have not heard or seen any problem with the Bailey diverter valves. Hardest part of the whole thing is to get the courage to start removing the little hoses that you can't see in the front of the engine bay . I do not think you will have any problems with either.
Old Oct 26, 2003 | 02:41 PM
toffeGT2's Avatar
No, there are not loss of Power/Boost. Just the Honking sound.
Old Oct 26, 2003 | 02:53 PM
Chordate's Avatar
Chordate is infamous around these parts
When does this sound appear?
Old Oct 26, 2003 | 03:42 PM
MKW's Avatar
MKW
MKW is infamous around these parts
Besides occas honking, you may experience inconsistent part- throttle response . That's what I had until I changed mine out and now my throttle tip-in response is always crisp.
Old Oct 26, 2003 | 06:25 PM
toffeGT2's Avatar
Thats what happen to mine, under partial-heavy acceleration I do some occasionally honking sound from lower gears. I hope is that Diverter values issue that causing the problem. But I didn't notice any power loss though; hope the new Diverter values will solve the problem.
Originally posted by Ruiner
If you get the honking while under partial-heavy acceleration, then they are probably leaking. I was getting the honking while under half-acceleration or so (sometimes under WOT from low gears). I bought and installed the Bailey Diverter valves and haven't had the problem sense. I was able to physically blow into (with my lungs) and hear the air leak through the stock valves.
PV=nRT.
Sep 9, 2022 06:06 PM
shifter_
Sep 8, 2015 12:07 PM
