K24 turbos
Old Oct 9, 2012 | 10:54 AM
Steve Theodore's Avatar
Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !
K24 turbos
Are standard K24s capable of about 500 whp with the right supporting mods and tuning? Thanks!
Old Oct 9, 2012 | 11:13 AM
johnspeed's Avatar
HI,Yes they are..No problem..Rear wheel..
I did it with my first Mods of a GIAC tune and Cargraphics exhaust...So have many others with a good tune and a good exhaust..
Old Oct 9, 2012 | 12:15 PM
c32AMG-DTM's Avatar
c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !
Yes, I believe so...
the recipe goes something like... free-flowing exhaust, upgraded 1.0 bar WGs, fueling support, good ICs and tuning should get there, +/- a bit.
However, if you don't already have one, you'll probably need an upgraded clutch too, to be safe, and if you're doing that, might as well do inlet piping "while you're in there," etc.
And, at that point, you've addressed the major areas needed for a rebuilt hybrid turbo K24 billet upgrade (18g or 20g or ???), or a turbo swap, to yield an even better result... which is why I think the seasoned guys say, "it's a slippery slope..."
Old Oct 9, 2012 | 12:39 PM
k24, 1.0-1.1 bar FVD tune, small cargraphic exhaust only i made 516rwhp on 93. on stock wastegates, stock clutch, RWD on DYnojet. also inlet pipes didnt add any power at that level
#TeamAIM
Old Oct 9, 2012 | 12:49 PM
johnspeed's Avatar
[QUOTE=prodigymb;3660377]k24, 1.0-1.1 bar FVD tune, small cargraphic exhaust only i made 516rwhp on 93. on stock wastegates, stock clutch, RWD on DYnojet. also inlet pipes didnt add any power at that level[/QUOTE
After I did my 18g swap with my Cargrsphics exhaust ,then I put the inlet pipes on after that swap...They didn't help at all either?..Night and day difference in power/spool when I went to the Millek exhaust though.
Old Oct 9, 2012 | 02:40 PM
Thank you prodigymb, that's very helpful as a solid reference.
Old Oct 9, 2012 | 02:45 PM
johnspeed's Avatar
And I am not a solid reference?...LOL
Old Oct 9, 2012 | 02:47 PM
I should have used the damn multi-quote! You're solid too!
Old Oct 9, 2012 | 03:52 PM
johnspeed's Avatar
Thanks Buddy,now I will stop pouting because I thought I got caught BSing here..LOL...
Old Oct 10, 2012 | 02:21 PM
REVS11's Avatar
REVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond repute
Are you talking REAL hp or "tuner HP" ?
For REAL HP it's a huge struggle, K24 doesn't have the flow needed. You need to go from 475 OEM crank to a at least 560 OEM crank to surpass 500 true wheel hp. Exhaust, LWFW, fuel pressure, max boost, intercoolers, seriously dangerous ignition timing, will barely squeeze you to 540-550 REAL crank hp with K24 (as in >85hp gain from an OEM 996 GT2).
Maybe with meth or E85 and big injectors to cool the hot side you could force it over the true 500 whp limit but it's so much work, so if you don't want to be scared to blow the engine up every time you step on it, go for a turbo that can give a lot more airflow.
Old Oct 10, 2012 | 02:54 PM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
I agree.
-tune
-exhaust
-intake piping
-intercoolers
-waste gates ?
-lwfw
You are talking about 470ish.
That extra 30whp, will have to be 16g billets. Is it worth it 3.5k in parts plus labor for the extra 30-50awhp ?
Old Oct 10, 2012 | 03:19 PM
johnspeed's Avatar
You guys might want to do a search and see how many members have hit 500 REAR WHEEL HP on K24 with tune and exhaust.
Old Oct 10, 2012 | 03:35 PM
18gs with open exhaust.. oEM wgs at 1.1 bar 525rwhp on a dynojet
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Oct 10, 2012 | 04:20 PM
REVS11's Avatar
Been here long enough to know a ton of people went over 500... tuner whp.
I even went 495 tuner whp with K16 turbos and exhaust once, just really aggressive timing and 1.0 bar boost. But real HP was just a 58 hp gain over OEM K16 (415 crank + 58 = 473hp crank). The dyno said 493 wheel hp though.
So, anyone looking for power needs to decide if they want a cool sounding tuner fantasy hp number, or a specific gain vs the OEM crank hp reference.
Old Oct 10, 2012 | 04:46 PM
johnspeed's Avatar
I even went 495 tuner whp with K16 turbos and exhaust once, just really aggressive timing and 1.0 bar boost. But real HP was just a 58 hp gain over OEM K16 (415 crank + 58 = 478hp crank).
So, anyone looking for power needs to decide if they want a cool sounding tuner hp number, or a specific gain vs the OEM crank hp reference.
HI,,What do you mean by tuner whp?..I dont understand that term tied in with the Dyno numbers?
I have been on many dynos during my stages and have seen many dyno runs..I have been around for a while also But yet this is something I have not heard before in terms of output.
I have my dyno sheets from the Porsche Exchange where I did it and I also did back to back tests there on a product..
