how to adjust headlights ?
Old Oct 18, 2012 | 09:59 AM
DNugget991GT3's Avatar
ok will try again tonight gents.
Old Apr 27, 2013 | 09:16 PM
Whereitsat's Avatar
Whereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond repute
Thread revival...
I can't find an Allen wrench long enough. Any links to one? No auto parts store has them. I did buy a long bit driver and a 5mm bit, but lost the bit behind the headlight. Humiliating and humorous at the same time.
Old Apr 28, 2013 | 08:44 AM
litecast's Avatar
litecast is just really nicelitecast is just really nicelitecast is just really nicelitecast is just really nicelitecast is just really nice
Did you look in your car's tool kit? Mine has the allen wrench in the kit.
Old Apr 28, 2013 | 01:27 PM
Whereitsat's Avatar
I don't have that one in the tool bag. It's missing three of them.
Old Apr 28, 2013 | 08:42 PM
Fallbangskid's Avatar
Fallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud ofFallbangskid has much to be proud of
I adjusted mine using a 5mm Hex that was like 10" long. I've dyno'ed it at +13 BHP at 8500.... Just saying :-)
FBS
Old Feb 18, 2014 | 03:14 AM
aerogt3's Avatar
aerogt3 is infamous around these partsaerogt3 is infamous around these parts
For those of you who are having trouble getting to the screws, just remove the headlights. It's way easier IMO. They slide right out and once you have them out, the two screws (a phillips screw inside a 5mm hex) sit ride on the side of the housing in plain view. Definitely easier than driving to the hardware store for a 10" hex, if you don't already have one.
Old Feb 18, 2014 | 05:39 AM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
Originally Posted by aerogt3
Is it easier to get to the adjustment (with a shorter screwdriver/hex wrench) if you just remove the headlight? I can't find a 10" 5mm hex anywhere near me.
The problem is you won't be able to see results of the adjustment without putting the headlight back in every time. If you search eBay you will find plenty of long hex wrenches.
Old Feb 18, 2014 | 06:33 AM
Whereitsat's Avatar
The issue could very well be the auto leveler, not the adjustment (or combination of both). There's a bracket that is vertical near the swaybar that must be attached for the auto level system to work. I don't have a pic (the cars in the shop), but someone may have a shot that shows it.
Old Feb 18, 2014 | 10:18 AM
Tim941NYC's Avatar
They is two of them, one the drives side front lca and one on the drivers side rear lca.
Old Apr 5, 2017 | 10:21 AM
HotRodGuy's Avatar
quick question, with the headlights out, there's two adjustments right above each other. If i'm correct, I need to do the lower one, but what is the upper one for?
Old Apr 5, 2017 | 12:30 PM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
to adjust left and right
Old Apr 8, 2017 | 11:55 AM
HotRodGuy's Avatar
Alright, next question. So I opened up the headlight, and my problem is the adjustment isn't turning. It's only the passenger side, I popped the driver side out to make sure it was functioning correctly.
Anyone ran into this. I've read a few posts here and there that say it sometimes come off track. But I don't see how you could do any kind of fix without completely removing the guts of the headlight.
davetherave
Bentley
Sep 16, 2015 06:30 AM
gpt817
Sep 8, 2015 10:21 AM
midtownlandman
Sep 3, 2015 01:17 PM
