Water Pump Replacement - DIY?
Old Nov 13, 2012 | 04:17 PM
vshugo996's Avatar
vshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to beholdvshugo996 is a splendid one to behold
Hi,
The water pump of my 996TT is broken.
I need A DIY Water Pump Replacement.
Thanks,
VS
Old Nov 13, 2012 | 05:41 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
What is your mileage? Just curious.
Old Nov 13, 2012 | 05:44 PM
deckman's Avatar
Interested. I understand it isn't simple. Lots of stuff has to be removed before you get to the WP.
Old Nov 13, 2012 | 06:01 PM
jpflip's Avatar
The repair manual is really good and the removal and installation of the water pump is perfectly explained...Start at page 529.
Old Nov 13, 2012 | 07:12 PM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
It is not that bad as long as you do not try to do it without dropping the motor. With the motor up you can get the pump off but it lacks a C hair of clearance to drop down.
Driver side....get under car and look up. It is right there. Do it from the bottom!
Old Nov 13, 2012 | 07:46 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Old Nov 13, 2012 | 09:56 PM
awdbiturbo1's Avatar
awdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant future
I did mine in June. It was easier than let's Say a B5 s4. I found it to be easy. Remove bumper lights lower the motor on the lift wals!
Old Nov 14, 2012 | 08:19 AM
Pmafia's Avatar
Pmafia is infamous around these parts
Just out of curiosity, what were the symptoms of the failing thermostat?
Old Nov 14, 2012 | 08:51 AM
Slider's Avatar
When the thermostat fails, you have 2 choices - either it locks open or locks closed. If it locks open, your car will take much longer to warm up, but will be drive-able to a point. If it locks closed, it will overheat as soon as it warms up and you'll have to park it until it's fixed.
Old Nov 14, 2012 | 11:39 AM
vshugo996's Avatar
60.000Km
turbotuner20v
Sep 11, 2015 12:02 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
