Bose = no roll cage ?
Old Nov 29, 2012 | 08:03 PM
Another P's Avatar
Another P has a spectacular aura aboutAnother P has a spectacular aura about
So from shopping around, it doesn't appear that the Bose stereo option makes life easy if you want to add a roll cage. Apparently, nobody makes a roll cage that installs without removal of the rear Bose speaker box.
So, some questions for all you experts :
1. What's involved in removing the Bose box?
2. Is this easily reversible or would it mess up something?
3. When I remove the box, does it look unfinished or odd?
4. Is there something else needing modification to install a bolt on roll cage?
Thanks!!
Old Nov 29, 2012 | 08:07 PM
32krazy!'s Avatar
i have the bose setup and used the 4 point a/p roll bar. no mods needed bolts right in . gmg also make a chromoly roll bar 4 point bolt in
Old Nov 29, 2012 | 08:24 PM
pwdrhound's Avatar
4. Is there something else needing modification to install a cool on roll cage?
Thanks!!
You can put in the Tequipment roll bar in there without having to mess with the Bose sub. If you want to remove it, it's a matter of two screws and removing the brackets. Takes about 10 minutes. I removed mine and this is what is looks like.
http://www.flickr.com/photos/87731073@N06/8231719438/http://www.flickr.com/photos/87731073@N06/8231719438/ by http://www.flickr.com/people/87731073@N06/, on Flickr
Old Nov 29, 2012 | 08:39 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Bose sub can remain while using the Tequipment Bar.
Old Nov 29, 2012 | 08:51 PM
Another P's Avatar
Awesome. Thanks for the quick and comprehensive responses! Photos are worth so much! I'm happy again
Happy holidays!
Old Dec 1, 2012 | 10:12 AM
joe731's Avatar
joe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to behold
Agency power
Agency power roll bar works with Bose as well. It has the same mounting positions as the tech. In addition the horizontal and diagonal members come go in and out easily. I got mine from vivid
VID997
97
Mar 20, 2018 02:23 PM
saline
Sep 21, 2015 12:58 AM
BLKMGK
Sep 19, 2015 03:51 PM
AdamNoone
Sep 3, 2015 04:15 PM
