abs light and psm failure
Old Apr 29, 2014 | 09:38 AM
  #31
rxbike's Avatar
rxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond repute
Originally Posted by clammy77
For the MAF, what is the exact part number?
Thanks! and is the MAF the sensor on the left of the engine compartment?
Yes the MAF in on the inlet pipe to the left of motor (driver's side)
Old Apr 29, 2014 | 02:53 PM
  #32
clammy77's Avatar
clammy77 is infamous around these parts
Thanks so much!
This is easily replaceable by myself?
The shop quoted 300usd to fix the abs/psm lights...and i am seeing the parts sold on ebay fot 60 bucks.
Also the shop told me the piece i need to replace is not the MAF, but the airflow sensor, but i couldnt find any info on that. Not sure if he is correct.
Old Apr 29, 2014 | 02:57 PM
  #33
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
Thanks so much!
MAF is "Mass Airflow Sensor."
Old Apr 29, 2014 | 02:59 PM
  #34
clammy77's Avatar
Exactly, but he told me no. I asked him again and he said thats not the part to fix, and 996tt doesnt have MAF. Sounds like wrong info to me. Weird thing is this shop is a very reputable porsche shop...
Old Apr 29, 2014 | 03:01 PM
  #35
ASLAN's Avatar
Hmmmmm - I would be getting a second opinion!
Old Apr 29, 2014 | 03:38 PM
  #36
rxbike's Avatar
Thanks so much!
MAF replacement is five minutes or less. Two torx screws, a clip to unplug the harness and reverse the process to replace and you are done. Ebay MAF are rebuilt unit with a new resistor (could be diode ) replace most of the time. I've had success with the Bosch unit on Amazon for ~180.00 bucks instead of the Porsche unit which is ~275.00 USD.
Actually I have a aftermarket MAF from amazon in my toolbox brand new I'd give away if you are interested. Pay for shipping to taipei and its yours.
(I did go with Hitachi MAF so no longer a problem)
Old Apr 29, 2014 | 03:51 PM
  #37
clammy77's Avatar
That would be fantastic thanks!
Quick question though, what is the major difference between an aftermarket vs. the Porsche unit?
And you also replaced it due to ABS/PSM issue?
BTW my email is edward.liu77@gmail.com, if you could send me an email we can just talk there
Old Apr 30, 2014 | 04:18 AM
  #38
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
I have the same problem and the car has had 2 new Bosch MAF sensors. It is running 1.2 bar, Ti exhaust,200 CEL Cats, 1 bar actuators, K&N with twin entry carbon airbox. The ABS/PSM light comes on under hi load acceleration ie from 30-40mph in 5th or 6th gear and throws a MAF fault on the durametric. Ive had another tuner in the UK tell me its the map !!! Any ideas guys
Old Apr 30, 2014 | 09:22 AM
  #39
wross996TT's Avatar
Get rid of the K&N filter.
Old Apr 30, 2014 | 09:32 AM
  #40
Tried it with and without the K & N, the rumour about the oil from the filters getting on the MAF's is just that a rumour.
http://www.knfilters.com/MAF/massair.htm
Old Apr 30, 2014 | 09:37 AM
  #41
rmc1148's Avatar
The oil from filters will mess with the maf more times then not.
Old Apr 30, 2014 | 09:48 AM
  #42
You think?
http://http://www.knfilters.com/MAF/3MAFSensorVideo.htm
Old Apr 30, 2014 | 09:50 AM
  #43
Going to do a proper leak test tomorrow with a smoke machine.
Old Apr 30, 2014 | 10:05 AM
  #44
rmc1148's Avatar
Yes that is what I have personally have found but I'm sure you disagree so please ignore= I was just trying to help.
Old Apr 30, 2014 | 10:10 AM
  #45
Not me dude, I thought it could be the same, took it out and cleaned it loads of times, even got a new stock filter and put that in. Have you watched the video as it is pretty definitive !!!!!
