Sprint Booster Throttle Box
Old Jan 7, 2013 | 09:00 AM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
Maybe it was 279 that I paid ?
Old Jan 7, 2013 | 02:40 PM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
Have a look on on You Tube Girls, under Sprint Booster
http://www.youtube.com/results?searc....1.NW3S-sOHJoE
Old Jan 7, 2013 | 07:00 PM
pwdrhound's Avatar
Originally Posted by Empyreal
What does it do, aside from the obvious? How does it do it? Only for a tip, as the website shows?
It is a simple amplifier that amplifies the signal from the throttle pedal to the electronic throttle control. It has nothing whatsoever to do with eliminating throttle lag. It just makes the throttle more sensitive and as a result makes it feel more "lively". In a nutshell, you will reach 100% throttle at a lower % of throttle pedal movement depending on the program you choose. For example, you will reach 100% throttle at 60% throttle pedal movement with the last 40% of pedal movement unusable..
Old Jan 7, 2013 | 07:08 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
Originally Posted by gearhead
If your car is flashed pretty much guaranteed the pedal delay was already removed.
Originally Posted by timccloud
289 is money well spent you won't regret. Great upgrade flashed or not.
Conflicting statements. Hopefully the tuners here on the 6 can give their input.
Old Jan 7, 2013 | 07:14 PM
unvmy996's Avatar
meh, its besicly the same thing that e46 m3 had , when you had the sport button pressed on.
Old Jan 8, 2013 | 10:51 AM
RCH's Avatar
RCH
Mine has arrived will have it on the car tom night
Old Jan 9, 2013 | 11:09 AM
RCH's Avatar
RCH
O*H S*H*I*T rushed to fit it this evening & I have a cable throttle on my May 2001 European TT !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!! I thought all TT's had an E throttle ???
Old Jan 9, 2013 | 12:25 PM
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
would i have the same issue with my 2001 turbo? it doesn't have the glove box.
Old Jan 9, 2013 | 04:09 PM
timccloud's Avatar
2001 has both fit the box it makes huge difference
Old Jan 9, 2013 | 04:58 PM
bad107's Avatar
then why didn't it work for Richard?
Old Jan 9, 2013 | 05:21 PM
timccloud's Avatar
Look harder. The sprint booster fits between the wiring loom and the throottle . I know because I have a 2001 turbo and I thought the very same thing Richard is thinking when I tried to fit my sprint booster. The turbo has both a cable and a wiring loom running to and from the throttle pedal.
Old Jan 9, 2013 | 10:07 PM
RCH's Avatar
RCH
I really will look again Tim but there is a steel Cable going in and no obvious electronic wires
Old Jan 9, 2013 | 10:12 PM
timccloud's Avatar
Yes I know it has both mine has both remove the pedal you will see it, don't worry I thought the same thing when I bought my sprint booster
Old Jan 9, 2013 | 10:20 PM
timccloud's Avatar
This makes me feel better I thought I was the only stupid one that couldn't find where to fit the sprint booster D)
Old Jan 10, 2013 | 02:10 AM
RCH's Avatar
RCH
my pedal looks like this http://forums.rennlist.com/rennforum...ed-feel-2.html does yours Tim ?
