Sprint Booster Throttle Box
Old Jan 10, 2013 | 02:53 AM
  #31
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
yes i think so been a while since i saw it and im at sea now on my ship so cant check.
but believe me richard there is a plug all 996 turbos are the same ask ur local dealer for help.
ill try to find the page in the manual and will post or pm
Old Jan 10, 2013 | 03:07 AM
  #32
timccloud's Avatar
check this link richard
full installation instructions
http://www.pelicanparts.com/techarti...nt_Booster.htm
I hope i have helped you.
cheers mate,
Old Jan 10, 2013 | 03:11 AM
  #33
timccloud's Avatar
Wink install pic
heres a pic
Here's a shot under the dash of the Sprint Booster installation. The plug for the accelerator is up under the dashboard: simply unplug it and insert the Sprint Booster device in its place. Then, reconnect the plug that connects to the chassis. The Sprint Booster is sandwiched between these two connectors.
Old Jan 10, 2013 | 04:28 AM
  #34
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
Yes Tim indeed you have !!!!, interesting to note that egas with a Porsche has a Cable pedal which then separately feeds as egas unit, this is very unusual & it will fit my TT afterall
Old Jan 10, 2013 | 05:52 AM
  #35
timccloud's Avatar
pleasure mate hope you enjoy
cheers
Old Jan 10, 2013 | 09:52 AM
  #36
RCH's Avatar
RCH
Tim you are the man, its going on tonite, hope I dont now drive it through the garage door
Old Jan 10, 2013 | 11:49 AM
  #37
RCH's Avatar
RCH
Ok its a bit of a b*i*t*c*h to fit as its really high up under the dash and behind the heater fan tube that is for warming your feet. You have to undo a philips screw and clip this tube to one side for access. You also have to lay upside down with your head in the footwell which is not especially comfortable on your back, if you happen to have carbon racing seats.
Once installed even though it was dark wet & cold its EPIC and particularly good at boosting up the Turbos early on the red setting, no doubt the best $280 I have ever spent !! The car is not hyper responsive when parking either.
Old Jan 10, 2013 | 01:46 PM
  #38
RCH's Avatar
RCH
So clearly very few of you have ever done this but the majority of you obviously need to .... get to work & live
Old Jan 10, 2013 | 03:53 PM
  #39
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
very interesting. I've always heard good things from people that have them but in the back of my mind the mod gremlins always were screaming "it's an ebay resisitor +20million hp scam" even though everyone seems to like them.
Old Jan 10, 2013 | 05:42 PM
  #40
timccloud's Avatar
reps for me then i guess thanks Richard knew you would love it makes the 2001 turbo heaps more fun
Old Jan 10, 2013 | 05:59 PM
  #41
ADAMNSONS's Avatar
ADAMNSONS is a splendid one to beholdADAMNSONS is a splendid one to beholdADAMNSONS is a splendid one to beholdADAMNSONS is a splendid one to beholdADAMNSONS is a splendid one to beholdADAMNSONS is a splendid one to behold
I am curious as well to see how this little box will help with performance. Someone mentioned it removes the lag between the pedal and the TB and you can remove that in the ECU Map… Is that right?
Someone said it will give you more percentage of throttle for given pedal percentage… If that is true, it would only speed up opening the throttle like pressing on the gas pedal quicker but we can do that ourselves so how does that help?
If it is just a delay removal, than wouldn't it be a better idea to go with the tune; put that money you will spend on the thingymagic towards your tune or just ask your tuner for an adjustment?
Can someone please clarify, explain what is really going on?
Old Jan 10, 2013 | 06:26 PM
  #42
pwdrhound's Avatar
I'm not sure how many times this needs to be repeated but IT IS NOTHING MORE THAN AN AMPLIFIER THAT MAKES THE THROTTLE PEDAL MORE SENSITIVE AND THEREFORE MAKES THE LAST X% OF THE PEDAL UNUSEABLE. IT INCREASES THE SENSITIVITY OF THE THROTTLE MAKING THE CAR FEEL MORE LIVELY BUT HAS ABSOLUTELY NOTHING TO DO WITH ELIMINATING ANY LAG... It's very much like the sport button on the BMW M cars albeit much simpler since the M cars alter the throttle maps in the ECU while this gizmo just boosts the signal from the throttle pedal. With that said, I loved it on the M3 as it make the car feel much more lively even though it added zero hp.
Old Jan 10, 2013 | 07:03 PM
  #43
mmmmm's Avatar
mmmmm is infamous around these parts
Yup just press the pedal faster.
Old Jan 10, 2013 | 07:57 PM
  #44
ADAMNSONS's Avatar
I guess we would agree that its a waist of money then right!
Old Jan 10, 2013 | 09:05 PM
  #45
timccloud's Avatar
umm no not a waste of money you twit try reading the posts, very worthwhile addition once you fit or you have a chance to drive a car with one fitted you would understand how good it is.
