Uh Oh! P1145 P1155 Error Codes
Old Jul 2, 2015 | 03:15 PM
Originally Posted by YJosephTT
LOL check the date of his post.....
Lol oopps
Old Jul 2, 2015 | 08:46 PM
mrmaass's Avatar
mrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond repute
Originally Posted by CBRacerX
Revival: Same P1145 issue here with my 2002. Got this once or twice a year ago, then about a month ago started getting it consistently. Replaced all 4 O2 sensors but after 100 miles it it back again! Have not cleaned MAF recently but did about a year ago. Not sure that could be related.
Are the other causes for this "O2 Pre Sensor Exceeds Value" code? I only get this on the 1-3 side.
I've been getting a p1145 for a couple years now, every few days. I've tried everything...even replaced all my lifters and it persists. I finally fixed it with a piece of black electric tape cut to the shape of a dime placed carefully over the CEL
Seriously, though...this one can be a real pain to get rid of. Good luck and keep us posted.
Old Jul 2, 2015 | 11:10 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
ditch the extenders and see what happens...I'm certain p1145/55 is related to flow over O2's...I fixed my issue with those CEL's, haven't had them back ever since decking the exhaust-side flange and getting rid of the extenders.
Cheers,
Will do - sealing rings shall be replaced. I got this with the OEM exhaust and no extenders,and continue to get it with SpeedTech exhaust (100 cell cats), new sensors and extenders.
Old Jul 3, 2015 | 06:10 AM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
Any time i ever had O2 sensor codes i always had a boost or vacuum leak.
if I were you if u dont gave a leak tester i would tighten every hose clamp you can see and zip tie every vacuum line u can find.
If that doesnt help get leak tester and follow markskis leak test instructions.
Old Sep 23, 2015 | 09:59 PM
jqhayden's Avatar
jqhayden is infamous around these parts
I'm getting the same 1145 fault code, my mechanic can't figure out. Setup is EPL flash, w/3" x-pipe exhaust. We've replaced the pre-cat 02 sensors (after cats are deleted), and maf is only a year old. Car runs great to be honest, just need to get this damn light off.
Next thinking of replacing valve lifters, but has anyone done this and it fixed the issue? This is an expensive test, given that's a motor-out, cam-out procedure. This is so frustrating!
Old Sep 23, 2015 | 10:05 PM
993GT's Avatar
pull your exhaust off and ensure the flanges are sealing, head to header, header to turbos, turbos to exhaust/muffler unit
Old Sep 23, 2015 | 10:12 PM
jqhayden's Avatar
Thanks 993GT. Will have this done tomorrow or Thurs and report back.
Old Sep 23, 2015 | 10:14 PM
Ask yourself when did it start ? What did you add or change before it happened. My guess as others said is exhaust leak, vacuum leak( do a pressure test and you will find it all) , throw on a stock exhauSt and revert to oem flash. That's a lot easier then opening up the motor.
Old Sep 25, 2015 | 04:02 AM
timccloud's Avatar
U got a vacuum leak for sure buddy buy markski leak tester and find try find its not so hard
longboarder
Sep 21, 2015 12:57 PM
intouch1
Sep 20, 2015 06:14 AM
nick-seattle
Sep 18, 2015 08:14 AM
