Can't Clear codes; can't start car
Old Jan 18, 2013 | 12:07 PM
HIX's Avatar
HIX
HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !
Hi guys, as an update. I did get the 'recharged' battery back in the car. I cleared codes and the car started up. It ran for about 5 minutes without anything happening and I shut it off.
Next day I go out to start and the codes were back and car wouldn't start.
So something is happening while the car is completely off to throw these codes? I pulled the seat up and checked connection to the DME (ECU, not sure the best term there). Is there any thing I could damage by unplugging it and plugging it back in?
I just don't understand how something could occur with the car completely off. When the car is running it will run for about the same amount of time each time and then I get 'PSM Failure' and 'Failure indicator' and car shuts off and won't restart.
Old Jan 18, 2013 | 12:09 PM
HIX's Avatar
HIX
Hi Jim, I do think you are correct. He said it failed the 'low cycle' (I think) and said he would have it ready to go the next day. It seems to be doing its job now.
Originally Posted by OptimaJim
You probably mis-heard him, as I don't know of anyone credible who could claim they are going to "rebuild" our batteries. Many of the "bad" batteries returned to us under warranty are just deeply-discharged and work fine, when properly-recharged. It is possible he is just charging the battery back up. I would be interested in hearing the outcome of this.
Jim McIlvaine
eCare Manager, OPTIMA Batteries, Inc.
www.pinterest.com/optimabatteries
Old Jan 18, 2013 | 12:51 PM
HIX's Avatar
HIX
I read this post and it's a little scary. Is there any way to check the PSM system? I'm going to trace wires today and see what I can find. I did install my own lowering springs and did brake pads about 6 months ago. But have had no PSM lights or issues.
http://www.renntech.org/forums/topic...abspsm-module/
Old Jan 18, 2013 | 06:03 PM
HIX's Avatar
HIX
UPDATE: I unplugged the ECU, and the PSM module. Checked all ABS lines and PSM wires in the wheel wells. As of right now the car is running fine and driving.
For some reason I can't get the engine bay light to go off even when the car is turned off. But that's my only issue right now.
Old Jan 18, 2013 | 06:41 PM
jpflip's Avatar
There was a thread on 6speed about a broken switch on the front latch. Both switch, luggage and engine compartment, operate both lights at the same time...
Old Jan 18, 2013 | 06:49 PM
Macster's Avatar
Reads like an alternator problem. The alternator is not able to generate enough power to meet the car's electrical needs. The battery does what it can, supplies what power it can, but when it gets low all sorts of things happen then the engine dies.
Leave the car sit a while and the battery could recover and you can get the same symptoms.
(A couple of weeks ago, during a visit to a Porsche dealer a Porsche tech had a Cayenne in the service bay doing the same thing and that was his diagnosis.)
Unless there is evidence of moisture in the car, under the seat leave the security module alone. The behavior does not point to that component and if you unplug it and plug it back in you risk static discharge or screwing up a connector.
Old Jan 19, 2013 | 10:27 PM
turbo964's Avatar
turbo964 is infamous around these parts
Sorry to see you are having problems, I know your pain! I saw that you posted in the southeast section to see if any people are down in your area and I am down in Columbus as well. Hit me up if you want to meet up sometime.
Old Jan 21, 2013 | 06:02 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
for my understanding a canbus communication problem....if one adress fails the bus is interrupted..
failures possible...cables at instrument k21
failures at bus cables abs
failures at bus cables psm
failure at dme
failure a secure module...connectors?
not easy to find...you can check your k21 instrument...connectors out and contact spray...dme connectors same and abs connectors same..(all without battery)
check cables along this route...good luck to find it ...
Old Jan 21, 2013 | 07:29 AM
HIX's Avatar
HIX
Very cool, I didn't know there were any enthusiasts around. I sent you a PM.
As of right now I think the car is back in operation. I unplugged ECU and PSM module and plugged back in and the car runs and drives alright. I'm a little gunshy driving far from home at this point. Just hoping I'm good from now on.
Old Jan 22, 2013 | 04:32 PM
HIX's Avatar
HIX
I know this fix was too easy. The problem is back. Drove the car for a short errand and got a mile down the road and it shut down. Seems like it was triggered by just going over some bumps or rough road.
Just had it towed back.
I can get the car to reset by unplugging the PSM module. So probably a dumb question but are there any PSM wires in the rear of the car or just the front?
Old Jan 30, 2013 | 02:15 PM
HIX's Avatar
HIX
Well, sent the car off to APR today. Hopefully they can figure out what the problem is. Fingers crossed.
Old Jan 30, 2013 | 03:06 PM
03 996tt's Avatar
03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future
HIX, do you have an apr flash?
Old Jan 30, 2013 | 08:38 PM
HIX's Avatar
HIX
No, they are just the closest shop to me. The closest Porsche dealer is Jack Ingram in Montgomery and I just figured I would try APR. I have an EPL flash.
Old Jun 27, 2020 | 07:27 AM
boyg's Avatar
boyg is just really niceboyg is just really niceboyg is just really niceboyg is just really niceboyg is just really nice
Hi mate, sorry for bumping an old thread, I have the same symptom and codes,.but the car is running, may I ask whats the find out and.fix finally? Thanks
Old Jan 21, 2021 | 11:49 PM
Sangrur's Avatar
Sangrur is infamous around these parts
Last week while driving my car just totally stopped running.
I bought a Durametric and have pulled codes from the car. But I can't clear them. When I hit clear codes they don't go away.
Here's what the codes are:
5522
DME: CAN message missing
ABS/PSM 5.7Module Identification
9110
DME control unit
Instrument Cluster K21Module Identification
Automatic Air Conditioning H01
Current Fault Codes
35:
Instrument cluster signal fault (see instr. cluster fault mem.)
I disconnected battery and let sit for 30 minutes and the car ran for about 3 minutes tonight. Then I had an ABS failure light come on and then this Failure Indicator Light.
I'm very frustrated.
Hi Guys, 1st post here and sorry to resurrect this old thread, but I too have this same problem. The car just died on me yesterday and has the same codes as Hix mentions. Additionally there is an image of an outline of an engine block in orange and the words 'failure Indicator' showing in the window under the rev display. The car won't even turn over. I got the above faults from Durametrics scan.
I can't pm at the moment, does anyone know what the solution was for Hix ? Or hopefully he will see this
Rupertlove
Jan 28, 2015 10:30 AM
doramon1313
Sep 29, 2013 08:26 PM
'02996ttx50
Mar 17, 2012 06:10 PM
jakeskiny
Jan 25, 2011 04:50 PM
jalmood
Oct 14, 2010 04:52 PM
