I need a Clutch - need help
My clutch is starting to slip noticeably in any gear above 4th as soon as the boost hits. With 53k miles and flashed ecu pushing up the power it is time for a new clutch I fear. Its sucks to have this unexpected expense, but I am trying to look at this as an opportunity.
I plan on buying the clutch kit and then having it installed by a local shop. This is my first clutch experience with a 996tt so i really would appreciate some help. I think it would be smart to upgrade the clutch to match the power and would appreciate suggestions. I have heard sachs stage 2 (sport)...clutch masters....help I am lost. Please be specific to what I need to buy...kit or part numbers...I have been researching this for a while and still am a little unclear what I need.
Thank you in advance
- Clutch Disc
- Pressure Plate
- Pressure Plate Bolts
- Throw-Out Bearing
- Throw-Out Bearing Guide Tube
- Flywheel
- Flywheel Seal
- Flywheel Bolts
- Clutch Release Lever
- Main Shaft Seal
- Clutch Alignment Tool
ERP Carbon/Carbon twin disc will pretty much never have to be replaced again at your power level and will drive nice
#TeamAIM
#TeamAIM
i have the sachs, it feels almost like stock imo, really glad i went that route, wasnt any harder to drive than when it was stock
search the web for a indy shop/ distributor , or you can order from sachs! just make sure you get all the incidentals and change your slave cylinder at the same time.. its already bad.. i changed mine to the 997 so it feels like a honda clutch when I'm in traffic.. the most any shop should charge you is 8hr!
SRE Performance Clutch Kit - Pro
[999764.001098]
Transmittable torque 890+Nm. This clutch kit contains the SRE Performance clutch cover and the rigid Performance clutch disc with special organic friction material. *** Special Edition for maximum transmittable torque! ***
instead of 1.038,00 EUR
only 954,96 EUR
you save 8 % / 83,04 EUR
( 19 % VAT incl. excl. Shipping costs )
Shipping time: sofort
I'd call them and make sure this, or whatever one you choose is the right one!!
[999764.001098]
only 954,96 EUR
