Any DIY on how to run audio cable to glovebox or rear center console
Old Mar 18, 2013 | 02:45 PM
thomapa1's Avatar
thomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of light
Thinking of storing my iphone in the glovebox or rear center console box. Currently have the cables poking thru the back of the center stack storage shelf.
Any DIY for how to run the cable from the headunit to either of these locations? Could not find any DIY help on a search.
Old Mar 18, 2013 | 02:57 PM
mrmaass's Avatar
mrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond repute
Doing it through the rear of the center console is easy. Just search for the DIY for shifter replacement and it explains how to remove the console...better yet, I still have a .pdf from B&M and I will attach it. Good luck!
Old Mar 18, 2013 | 03:03 PM
thomapa1's Avatar
thank you sir!
Old Mar 18, 2013 | 03:29 PM
FI_FTW's Avatar
FI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond repute
I have the cable come out the back of the console and routed it through the back of the glovebox. Completely invisible.
Old Mar 18, 2013 | 04:18 PM
thomapa1's Avatar
Any need to poke a hole in the back of the glovebox or is there enough gap (open or closed) to get a cable into the glovebox from the back of the headunit?
I kind of like the glovebox option better.
thanks
Old Mar 18, 2013 | 05:27 PM
mrmaass's Avatar
There is plenty of room with no hole to go in behind the glovebox. This is how I mounted my iPod in my previous NA 996 (2003). I agree, that is a better place to put it.
Old Mar 18, 2013 | 06:07 PM
MBH's Avatar
MBH
MBH has a spectacular aura aboutMBH has a spectacular aura about
There is still no way to do this (iPod integration) while keeping the PCM2, right?
Old Mar 18, 2013 | 06:45 PM
thomapa1's Avatar
I redid my system and have my iPhone connected via a cable from the behind the headunit to the storage shelf just below. Will move the cable and iphone to the glovebox to clean it up. Then I can access my iPhone functions from the double DIN display.
Old Mar 18, 2013 | 07:33 PM
MBH's Avatar
MBH
So you have a new headunit then, correct?
FWIW, I looked into the PCM2.0 & the iPod thing after my post, turns out you can - about $550ish from Dension (gateway 500) to integrate an iPod into my 03's navigation headunit and can get bluetooth that way too.
Old Mar 18, 2013 | 07:48 PM
thomapa1's Avatar
Correct. Expensive gadgets but its great to have your own tunes. My local radio stations are terrible and I did not care for XM.
Old Jul 6, 2013 | 03:01 PM
split's Avatar
split is infamous around these partssplit is infamous around these partssplit is infamous around these partssplit is infamous around these parts
Question
I just installed the Dension Gateway 500S into my PCM 2.0 996 porsche MOST system. Every works fine, but I get an error saying "CD Changer Unavailable" when i turn the car on. Has anyone else had this issue?
COBB Tuning
Jan 1, 2025 09:02 AM
3WDistributing
31
Oct 27, 2017 01:26 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
Sales@epl
996 Turbo Vendor Classifieds
Sep 7, 2015 02:05 PM
