Rear Main Seal leak
Old Mar 23, 2013 | 07:29 AM
Kapoosh1's Avatar
Kapoosh1 has a spectacular aura aboutKapoosh1 has a spectacular aura aboutKapoosh1 has a spectacular aura about
Rear Main Seal leak
Having a clutch/flywheel replaced on my turbo. He noticed the RMS was leaking...
Is there anything else I should be checking/replacing while the transmissions out, I didn't realize the turbo had an issue with the RMS leaking. Luckily the local dealer has the seal in stock.
Old Mar 23, 2013 | 09:25 AM
ATL97gts's Avatar
ATL97gts is infamous around these parts
I don't see this as a Porsche Turbo issue. This happens to cars of all kinds... On the N/A 996 cars this was a sign of other issues, but not Turbos.
Old Mar 23, 2013 | 09:44 AM
raineycd's Avatar
Well that sucks. At least the tranny was already out! Don't think it is a chronic problem for the turbo, but can happen with any car.
Be sure to at least check the slave/accumulator for leaks - much easier to replace while tranny is out.
Old Mar 23, 2013 | 09:45 AM
'02996ttx50's Avatar
pretty common i think... mine's leaking *minimally* .. and will until i need a clutch.
Old Mar 23, 2013 | 10:11 AM
Kapoosh1's Avatar
I'm replacing the slave and accumulator at the same time. Started leaking the same week the clutch started slipping. Starting to think I should've done the GT2 conversion, but I feel like this setup lasted 10 years, so i'll take my chances and save some money.
Old Mar 23, 2013 | 10:27 AM
johnspeed's Avatar
Hi,Not that common on turbo models..
Old Mar 23, 2013 | 03:14 PM
common, insofar as i've heard of it, had it.. and .. it happens. just not every day, thankfully
Old Mar 23, 2013 | 04:19 PM
johnspeed's Avatar
On Non turbos its common,,different motor,,,not Turbos..
I had a 1999 C-2 and a 2003 C-2 in which both needed it and alot of my PCA members with them and Boxters needed it.
I have 42,000 miles on my Turbo and I dont know of any in my circle with Turbos with that issue> Which is Great..
Old Mar 23, 2013 | 04:58 PM
funny! i've not heard of the rms problem in n/a cars.. but not like the ims issue! thx god for split case mezger's, huh? .. but yeah.. i've known a cpl guys have had the issue, and i do.. and well. i don't like to talk about it much
i don't need a clutch.. so i leak. there.. i said it
Old Mar 23, 2013 | 05:09 PM
ttpopo's Avatar
ttpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond reputettpopo has a reputation beyond repute
the RMS is not unheard of on mezger engines, but pretty rare. OTOH, it affected about 5% of the NA 996/986 which works out to around 7800 cars! It still existed to some extent with the NA 997. I think the DFI engine finally cured it.
Last edited by ttpopo; Mar 23, 2013 at 05:28 PM. Reason: forgot to specify NA cars
Old Mar 23, 2013 | 05:26 PM
Originally Posted by ttpopo
the RMS is not unheard of on mezger engines, but pretty rare. OTOH, it affected about 5% of the 996/986 which works out to srounf 7800 cars! t still existed to some extent with the 997. I think the DFI engine finally cured it.
i knew i wasn't the "only one"
Old Mar 23, 2013 | 05:30 PM
ttpopo's Avatar
Certainly not, however, my 5%was referring to NA cars.
Old Mar 23, 2013 | 05:33 PM
****! oh well.
Old Mar 23, 2013 | 08:31 PM
ATL97gts's Avatar
There have been enough that there's an upgraded version. That says something.
Old Mar 23, 2013 | 08:52 PM
johnspeed's Avatar
They just replaced it with the newer version used on the 997..Like they did with the coils..
