Push through setup
Old Mar 27, 2013 | 09:37 PM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
Push through setup
Just finished up my push through setup tonight... my cousin who is a welder helped make the parts for me.
The car seems like it sucks air through the left turbo then right turbo and back and forth usually on idle and you can hear it slightly when just cruising. Is that normal? I'm running filters straight off the turbo.
Also thinking about getting the optional K&N covers since its pretty exposed to dirt at that location.
I don't actually have a pic right now of the final installed version. It basically looks like the one w/ everything on it but the meth line was routed under and tied nicely and a few other things cleaned up.
Parts used:
IPD 3" Y-Pipe
2x Tial 50mm BOV
K&N Filters
Custom Piping to join everything together
3 days of blood, sweat and tears! enjoy!
- David
Old Mar 28, 2013 | 08:05 AM
looks nice. still have a MAF?
#TeamAIM
Old Mar 28, 2013 | 09:55 AM
unvmy996's Avatar
What is a push through ? Do you mean blow through ?
Old Mar 28, 2013 | 10:24 AM
johnspeed's Avatar
Wow,thats looks like a big y-pipe there.
Hope that system really runs well for you..
Old Mar 28, 2013 | 10:27 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Awesome !!! Looks very great
Whats all the mods you have on the car ?
Old Mar 28, 2013 | 10:41 AM
SSMugen's Avatar
No MAF. Its on a MAFless tune by Proto. Its funny for pretty much the entire time I have owned the car it would sometimes stall out randomly when the RPMs dropped too low about once every 100 miles. I've replaced the MAF about 4 times in the last 6 years and now with the new MAFless tune it hasn't done it once in the last 1000 miles.
I can really hear it suck air from side to side on decel when i let go of the gas... here is a vid of it on a cold start... you can hear the intakes sucking air from side to side.
pumptech's Avatar
pumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond repute
I would argue it is being pushed through by the turbos.
Old Mar 28, 2013 | 10:46 AM
SSMugen's Avatar
Hmm whats the difference? Sorry maybe I said the wrong thing...
IPD/BBi make the Y-Pipe
Thanks!
GT2871, 72# injectors, IPD Ypipe, Evo intercoolers, Tial BOV, Europipe, 74mm TB/Plenum, ClutchMasters Stage 3, GT2 Slave, JRZ, HRE & Proto Tune.
Old Mar 28, 2013 | 11:01 AM
johnspeed's Avatar
What type of exhaust,cats? Thanks
Old Mar 28, 2013 | 11:09 AM
orbelo's Avatar
orbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud oforbelo has much to be proud of
I have the same thing happening on cold start. It sucks air from each side and you can hear it exactly as your video. Once the car is warmed up to 180degrees, sound goes away. No issue on the driving once warmed up properly. Sweet setup! Congrats...
Old Mar 28, 2013 | 11:29 AM
SSMugen's Avatar
Europipe w/ 100 cell
Awesome! thanks for the reply Orbell
Old Mar 28, 2013 | 12:16 PM
HIX's Avatar
HIX
HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !
It's ALIVE!!!!
Old Mar 29, 2013 | 02:11 PM
SikPorscha's Avatar
SikPorscha is a splendid one to beholdSikPorscha is a splendid one to beholdSikPorscha is a splendid one to beholdSikPorscha is a splendid one to beholdSikPorscha is a splendid one to beholdSikPorscha is a splendid one to beholdSikPorscha is a splendid one to behold
Where is the methanol injection tap? Are you using for cooling or octane purposes? Did you tap one port or two for injection?
Old Mar 29, 2013 | 02:25 PM
SSMugen's Avatar
Tapped one port. Its for octane since we only get 91 here in Cali.
Old Mar 31, 2013 | 09:41 AM
Tim941NYC's Avatar
The surging is normal, the turbos are spooling on cold start(retard timing aka anti lag, but used to heat the cat's up) and the boost has now to go. You can put lighter springs in you bov's that make them open at idle. As soon as you lose manifold vacuum the bov's will shut. Push through usually means turbos are feeding air thru the maf instead of pulling it.
Nice work
