Worth new map for 93 octane?
Old Apr 15, 2013 | 09:40 PM
Whereitsat's Avatar
Whereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond repute
I recently purchased a Turbo from California with a Sharkerks tune and AWE exhaust. Being in Houston 93 octane is readily available. Is a new map worth it?
Old Apr 15, 2013 | 09:59 PM
aa909's Avatar
aa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond repute
tough call, how much is the re-map for 93?
either way definitely use 93 octane since you can get it (jealous!). Going from 91 to 93 octane the ECU should adapt to the 93 octane and advance the timing for more power regardless of the map.
Talk to Sharkwerks and get the details of what in particular you can expect with the 93 map vs just running 93 octane + 91 map, and of course the cost
Old Apr 15, 2013 | 10:09 PM
johnspeed's Avatar
YES,,IMO..
They would be the best suited to answer that But I hope they would do something for you with that at a nominal charge..
Good Luck
Old Apr 16, 2013 | 05:00 AM
Whereitsat's Avatar
I'll give them call later today. Thanks!
Old Apr 16, 2013 | 09:38 AM
dustent's Avatar
dustent is infamous around these parts
Not to tread-jack - but I picked up an '02 non-x50 with a tune, not sure if it's 93 or 91. I'm in Denver and can only get 91. As far as I've found, there isn't really anyway to determine what tune I have, so I'm not sure if it's dangerous to run it hard on 91.
Old Apr 16, 2013 | 09:49 AM
996turbo4365's Avatar
996turbo4365 is a name known to all996turbo4365 is a name known to all996turbo4365 is a name known to all996turbo4365 is a name known to all996turbo4365 is a name known to all996turbo4365 is a name known to all
After modding my vete and also hemi's... to me data log is the key to make sure everything is fine...I seen many times a 91 octane tune still produces knock running 94 octane...the ECU can compensate if it see knock by pulling timing but I rather not have the ECU do the work in protecting my engine.
Old Apr 16, 2013 | 11:44 AM
Whereitsat's Avatar
Sharkwerks states that the 91 octane tune will adjust to the 93 octane fuel. He also mentioned that I should see anywhere from .8 to 1.0 bar - weather dependant. However, I only see .8 bar.
Old Apr 16, 2013 | 11:56 AM
johnspeed's Avatar
Sorry to say but to me, that sounds kinda lame and with only getting that much boost?
Old Apr 16, 2013 | 12:03 PM
Whereitsat's Avatar
I feel the same way. But worse because it's happening to me :0
Old Apr 16, 2013 | 12:24 PM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
With 93 you should have a solid 1.1 to 1.2, you are leaving alot of "safe" power on the table.
Old Apr 16, 2013 | 12:56 PM
docboy's Avatar
docboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond reputedocboy has a reputation beyond repute
How much does a remap go for?
Old Apr 16, 2013 | 01:10 PM
Whereitsat's Avatar
Not sure. I didn't ask as I wanted to digest the information.
Old Apr 16, 2013 | 01:38 PM
Vendetta's Avatar
Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !
Note to self: no Sharkwerks.
-V
White991TT
Mar 8, 2016 06:01 AM
COBB Tuning
Nov 3, 2015 08:39 AM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
