New project .. K24/20G 6speed 996tt
Old Apr 27, 2013 | 12:22 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
6Speeders ..
We will start new project on my friend 996tt , we will upgrade our K24 turbos by 911tuning for sure , and go for 20g ,
I will list the mods :
- k24/20g (911tuning)
- WGs 1bar (911tuning)
- methanol injection
- intake filters direct to the turbos
- tial BOV will be on the Ypipe
- upgraded injectors (still not sure 60lb or 72lb)
- HKS evc6 boost controller
- custom 3" exhaust system
- softronic mafless tune
I just worried about the fueling , but we are going to upgrade the injectors and install inline 044 pump to support fueling !!!
I will list alot of pics once we have all the parts home !
We just looking to get 600whp ! Hope we reach it
Stay tuned
Old Apr 27, 2013 | 12:27 AM
layinback's Avatar
layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !
Originally Posted by ysfg35
6Speeders ..
Stay tuned
Sound like a whole lotta fun to me! Markski will take care of you bro!
Good luck and you are in good hands!
Old Apr 27, 2013 | 12:39 AM
ysfg35's Avatar
I did alot of great projects by him
Hope we get what we want !
Thanks so much for your post
Old Apr 27, 2013 | 12:54 AM
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
Looking forward to the end results!
Old Apr 27, 2013 | 01:07 AM
Fasoole's Avatar
Fasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant future
Is that a 6speed or tip car?
Old Apr 27, 2013 | 02:15 AM
ysfg35's Avatar
It gone be 6speed bro
Old Apr 27, 2013 | 08:21 AM
johnspeed's Avatar
Hope it turns out to be what you wanted..
Old Apr 27, 2013 | 08:23 AM
32krazy!'s Avatar
i have seen the intake on the turbos and wonder just how safe this idea is. the amount of debis and water it will be subjected to combined with the low mounting position seems like a potential disaster.
can you imagine running thru a large puddle of water or hitting a small piece of retread tire ? just a thought
Old Apr 27, 2013 | 09:34 AM
Luke_01's Avatar
Luke_01 is infamous around these parts
32krazy!
"i have seen the intake on the turbos and wonder just how safe this idea is. the amount of debis and water it will be subjected to combined with the low mounting position seems like a potential disaster.
can you imagine running thru a large puddle of water or hitting a small piece of retread tire ? just a thought"
Where did you see the intake sir? Did I miss something?
Old Apr 27, 2013 | 10:16 AM
unvmy996's Avatar
6Speeders ..
Stay tuned
no clutch??
also, are you running bigger Y pipe im assuming?
if i were you i would do the 997 TT intake manifolds and the Ipd plenum abd TB.
Old Apr 27, 2013 | 11:18 AM
ysfg35's Avatar
Yes , hope so sir
Old Apr 27, 2013 | 11:21 AM
ysfg35's Avatar
In our weather , its too much hot so no rainning
You are sure , it get dirty fast , but i can clean it monthly
I tried this setup and it worked well
Old Apr 27, 2013 | 11:22 AM
ysfg35's Avatar
Originally Posted by unvmy996
no clutch??
Thanks for your post ,
I will change the clutch for sure !
We will remain use the stock Ypipe
Old Apr 27, 2013 | 11:33 AM
unvmy996's Avatar
if your going through all these mods, it would be a shame to cut corners....
i would do a real Y pipe, the 997 tt intake manifolds ,the Ipd 74 plenum and TB.
regardless good luck.
Old Apr 27, 2013 | 11:42 AM
ysfg35's Avatar
You are right
We will switch to 2.5" Ypipe with 74 plunim inthe future , i just want to finish the main mods !!
Thanks for your recommendations
