Tip owners, is this normal?
Old Jun 28, 2013 | 09:56 AM
996turbo4365's Avatar
996turbo4365 is a name known to all996turbo4365 is a name known to all996turbo4365 is a name known to all996turbo4365 is a name known to all996turbo4365 is a name known to all996turbo4365 is a name known to all
Hey guys,
When I got WOT From a dead stop, the 996 feels like it bogs for the first couple of feet and then screams to redline. This happens in Manual or D and with PSM off. I know it's a six and not alot of torque before the Turbo kicks but it seem like the TC should flash a little higher to help the 996 get off the line faster.
My last SUV can cut a 1.7 60ft on a stock converter.
input welcome please
Old Jun 28, 2013 | 03:35 PM
Valley996TT's Avatar
Valley996TT is just really niceValley996TT is just really niceValley996TT is just really niceValley996TT is just really nice
Are you starting in 1st gear? The tip usually takes off from a stop in 2nd gear, unless you stomp the gas and it then quickly shifts to 1st and then takes off.
Old Jun 28, 2013 | 03:55 PM
yes...did the 2nd gear WOT and it did the quick shift to 1st which I did not really like.
I tried the 1st gear WOT and coming out of the hole is very slow for a few feet and then it screams to redline.
thanks
Old Jun 28, 2013 | 04:01 PM
pumptech's Avatar
pumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond repute
Think that's just normal lag until turbos kick in..drive another comparably equipped tip to know for sure. They a dog off the line!
Old Jun 28, 2013 | 09:33 PM
nizzki's Avatar
nizzki is infamous around these parts
It's normal, until the turbos spool up it's a bit of a dog. Once you hit 2.5k rpm it'll take off though. Starting from second in M will make it feel like a corolla.
If you want to really launch it you need to stomp on the brakes, but i'm too chicken to do it myself.
FWIW, I think that in one of the reviews I've read (MotorTrend?) they said that using that method makes it go 1.5s quicker from 0-60.
Old Jul 1, 2013 | 07:27 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Totally normal. Try brake boosting from a dig. Foot on the brake, slight throttle until car starts to move. Then launch. Another way to launch harder is to have your TC stall raised to 3000rpm. The best I could ever get out of my tip was a 1.7 60'.
Old Jul 1, 2013 | 07:03 PM
machinegunt's Avatar
machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !
+1 on the TC! Mine hauls *** out off the hole when I brake boost it!
Old Jul 1, 2013 | 07:23 PM
Another P's Avatar
Another P has a spectacular aura aboutAnother P has a spectacular aura about
BHT and Machinegunt,
I've done the braking thing with modest change. It does not want to stay put beyond 2200 - 2300 rpm. Does raising the stall speed in the TC create any reliability or other problems?
I'd love to do that, as my 1/4 mile times are horrible for the 60' times.
Just scared to play with that. Do tell!
Old Jul 1, 2013 | 07:35 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
Hold the brake , half throttle ,,,, more brake full throttle - go. The front tires spin just a little. You go then bog a little then really go. That seams to be the best. Did 11.6 s the other day with just a tune .
Old Jul 1, 2013 | 09:59 PM
Raising the stall speed won't hurt a thing! Very common mod with a Tip! Evoms, GMG, and many others can perform the mod for you!
Old Jul 1, 2013 | 10:45 PM
Higher Stall TC may generate a bit more heat for the Tip.
thanks for all the input!
Old Jul 2, 2013 | 09:06 AM
That's correct.
Increasing my stall hurt my 60-130 times. It was a trade off for better launch times.
docboy
Sep 6, 2015 06:57 AM
