Consequences of over-filling oil???
Old Jul 15, 2013 | 06:54 AM
  #31
johnspeed's Avatar
Originally Posted by TMWTP
Should I be concerned about any long-term affects?
HI,Most of the time I have seen on other vehicles that were over filled to the point that it did cause problems with seepage and blow by,,,,if corrected by removing the excessive oil when first realized ,,,, everything went back to normal....
But if you did do sustained high RPM driving, thus high oil pressure, when it was over filled you could introduce oil seepage at the weakest point in a gasket/seal area...
Good Luck..
Old Jul 15, 2013 | 05:41 PM
  #32
TMWTP's Avatar
TMWTP has a spectacular aura aboutTMWTP has a spectacular aura aboutTMWTP has a spectacular aura about
They're sending a flatbed tomorrow!
Old Jul 15, 2013 | 06:29 PM
  #33
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
Originally Posted by pwdrhound
I bet the knuckleheads only drained the crankcase and forgot the drain the oil tank. Then they added 9 quarts = massive over fill. Can you PM the shop name?
I'd bet money this is exactly what happened. Worst case is you "hydraulic" (bend) rods when they try to compress a chamber full of oil on the compression stroke. Hopefully not the case!
An eerily similar thread here: https://www.6speedonline.com/forums/...gine-gone.html
Old Jul 15, 2013 | 11:02 PM
  #34
TMWTP's Avatar
That's not very reassuring.
Old Jul 16, 2013 | 06:14 AM
  #35
'02996ttx50's Avatar
hopefully you've drained enough oil at the outset to have minimized the potential for catastrophic damage. my money is on you have. GL. ...
Old Jul 16, 2013 | 12:57 PM
  #36
deckman's Avatar
+1 on this, I'd give 10:1 odds on it. If they haven't done any more work on it yet be sure to be there and oversee what they do. Idiots.
Old Jul 16, 2013 | 04:26 PM
  #37
TMWTP's Avatar
Just got an e-mail from them that the car is running, and has been test-driven already. I just got back to town, so I haven't had a chance to discuss things with them, but I did ask that they check the plugs. Not sure the best way to check for a bent rod though.
In my other hobby (rockcrawling), vehicle roll-overs are common, as are the problems associated, such as oil in the cylinders. There were no knocks that I could hear when it smoked, so I'm hopeful that there wasn't that much oil in there. I guess I'll find out more info tomorrow.
Old Jul 16, 2013 | 06:35 PM
  #38
King James's Avatar
King James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond repute
Wow that's scary as hell can't believe that.
Did you find out what they did to fix the issue exactly? I'd want to know exactly how much oil they drained from the car. I'd also have them sign or do something stating they overfilled the car should an issue arise. Get a new bill for this service that states the issue and remediation.
Old Jul 16, 2013 | 09:47 PM
  #39
TMWTP's Avatar
Btw, here's the email from today:
Hi John,
We cleaned and drained everything (crankcase, oil res, turbo oil collection containers, inlet pipes, boost pipes, MAF, and air box). Air filter was replaced. We redid the oil change and put the CORRECT amount in. The car has been driven several times by ***** and runs well. No issues were found after we performed the work. If you would like me to drop the vehicle off at your home, I can have that arranged tomorrow. Or, you are more than welcome to come pick it up.
So, things are looking good. I will require something in writing to offer some sort of guarantee on their work. Not sure how binding it would be though.
Old Jul 16, 2013 | 10:29 PM
  #40
Engine Guy's Avatar
Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !
A compression test could tell you if a Rod is bent.
Old Jul 17, 2013 | 06:44 AM
  #41
helped in no small part by your immediately draining some oil and not driving around. good news.
Old Jul 17, 2013 | 04:03 PM
  #42
TMWTP's Avatar
Got it back, everything is tip-top. Runs great, feels great, sounds great. I talked to the shop foreman (Porsche trained tech), he admitted that he assigned my car to an Audi tech who didn't know there are 4 drains on a 996 turbo. I got very lucky since I did not drive the car much, or hard before the problem was found.
Old Jul 17, 2013 | 04:29 PM
  #43
croach's Avatar
croach is infamous around these parts
They are the lucky ones. You almost got a new engine
Old Jul 17, 2013 | 06:15 PM
  #44
how did i know this.
but this: "he didn't know there were four drains on a porsche turbo"
Old Jul 18, 2013 | 06:46 AM
  #45
c32AMG-DTM's Avatar
c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !c32AMG-DTM Is a GOD !
I think that even that is kind of a "cop out" reply. Apparently the tech didn't even know there are two main plugs. The turbo res. tanks can be skipped without a ton of used oil still being left in the system.
